Often times I would wonder why I read so many posts about impedance matching but hardly ever any posts about gain matching aside from in carts-phonostages. Not just gain but voltage drive as well especially for many of us who bi-amp (including those using subs fed from the pre's secondary outputs). We also tend to use long runs of interconnects.
I use one preamp that deals with this is a bit different way. The Valvet Soulshine has two knobs in the middle. What they do is control the input sensitivity for the sources. When you play with them the first thought is that the can be used as balanced controls. The more you listen though it becomes obvious that they shouldn't. Every mismatch between L and R show different distortion spectra which are clearly audible as notes sound...... wait for it
.....a tad
hirsute.
I suppose this also cuts the usage of the available peak gain thereby indirectly rendering it adjustable. I have found that there is indeed a sweetspot and these vary according to the amps they are used to drive. Same goes albeit more directly for the input stage.
@Steve
I don't see at all why there would be an adjustable gain option for the LL1 when it was designed specifically for the ML3. Specs show it would also do well with the greater majority of amps out there. Still, personally, I can't even think of the LL1 without thinking of the ML3. I suspect that an overwhelming majority of LL1 buyers are buying them to complete the Signature set.
