Micro, thanks. The main thing is you are happy, but these kinds of games by manufacturers in spec'ing thier gear is tiresome to me these days....the standard spec is simply something like signal to noise, A weighted, 98 db or max output noise, 100 microvolts, A wighted, etc. Not that hard, really.
Tom
Micro has made me smile, no wonder his product has rather good measurements, not only is it a reference model ARC preamp (some of the best that are measured), it is the freaking Anniversary 2-box setup with a seperate mains
Nice gear Micro.
But as mentioned in a post not far back, these ignore the affects of as said grunge that is potentially on the mains that then affects these figures, furthermore we have the example of the grounding solution being uprated in someone's house that anecdotally also improved the noise floor.
I have heard a 6-way extension add a lot of noise (we opened up and could not see much wrong visually but could not test it at the time).
Also I feel some need to consider listening distances, not everyone can listen 4m and over away from a speaker and this is especially true in many European and Asia houses.
Seperate to the noise floor, I can hear the transformer core saturation buzz of my CD player just under 3m away (in our quietest room) due to our mains (also can hear PC monitor and Pioneer TV screen "sing its pretty sinewave"), as mentioned this may not bother some but it comes back to a listener's threshold and tolerance to such noises.
Furthermore as I mentioned earlier not all products are designed-engineered-built to the same level, or have the space to implement and so cope with the various demands of mains characteristics,etc.
Edit:
With all that said, the OP showed a concept that enables seeing all the electrical signals on the mains, and maybe just maybe this would be useful to test the practicality of mains filtering products (could see signatures both sides of the filter-regenerator) and could be used in such scenarios as the described ML controlled environment.
It is a great and well thought out concept-product.
It may be best if we all agree to disagree on the importance of such a product and the
potential affect of mains grunge and potential benefit of mains related products and grounding solutions.
Cheers
Orb
