I'm of a similar ethos, Roger.
I prefer optimizing an original factory stock product from a top-tier company by ensuring it's operating at optimal factory specification rather than modifying it...that way, I have a superb idea of the original designer's/manufacturer's concept of excellence.
Now, should I be favored with another unit...I would seriously contemplate minor, easily reversible performance enhancements. For example, with a Ferrari -- I might consider exchanging the stock exhaust, i.e. cats, etc., for a Tubi, while maintaing all of the original parts for future needs
Roger, is your two-channel system listed somewhere![]()
Maybe I should purchase a tubi exhaust for my system,nah I'll save that for my future 550 Marenello,
You have to be careful with the A820, there are many components that were spec'd that are special and to replace would seriously degrade reliability.
Some replace the opamps but I see no benefit as these are Signetics low noise versions. There could be an upgrade there but I think were splitting hairs. The resistors and all the film caps should not be replaced. The e-caps can be and would upgrade the sound and not effect the value. Only the best caps would warrant to be used though and these are NLA, any others are of no interest to me. I would also bypass one film cap with teflon. So all in all a simple project.
My system is here. The speakers are all custom along with other bits and pieces. I'll be glad when it's all done.
http://www.whatsbestforum.com/showthread.php?1769-My-2-channel-experiment
Cheers,
Roger
