Put on your ear phone. Here is another taste of AtlasSL. Recorded from bare bone Samsung S8.
Next time will be Scheherazade that you like.
Tang
But tbh, I was just teasing you when I asked that question. I knew what the reply would be, and thought maybe Tang will read that and now get a Durand.
Hi Tang. It may be better if I add two photos to show such a setup. Not beautiful, but gets the job done (smile).
I believe another member here, who has a Durand Telos but not a saphire one, now has 2 SATs. Why didnt he buy a second Telos I dont know. He also uses both AtlasSL and EtnaSL I think. If I have a NVS I will be interested in Durand but I dont have a NVS.
I also have no iPhone Kedar.
Tang
Jonathan,Hi Tang. It may be better if I add two photos to show such a setup. Not beautiful, but gets the job done (smile).
The black Erodion. Once it arrives, please describe how you get along with it.
I am honored! Thank you .
do you know if this other member's standard Telos has the wood arm wand, or the composite one?
best regards,
Mike
Jonathan,
Thanks for posting this. One of the concerns I always have with a tonearm that has a removable headshell...is due to the inevitable break in the wiring at the junction. ( Plus, the possibility that there will be additional vibration at the junction). Your photo displays a way around the wiring break, but the vibration issue is going to be still an issue. Am I right to presume that you prefer a tonearm that has a fixed headshell with the wiring going all the way from the headshell/cartridge to the phono stage? This has always been my preferred design. ( Having owned tonearms with the aforementioned removable headshell and -at least to my ears - consequential losses).
which one is yours, composite right?
Mike, You owe it to yourself to try an Etna SL. It handily surpasses the Anna on my NVS/Telos Composite. The Etna SL completes what the Anna starts. It has a full harmonic structure which I find lacking in the Anna. Think- trumpet blatt, drum skin resonance, full piano tone, as well as, startling dynamics. The Anna can’t complete on these counts. There’s an undeniable clarity to the Anna, but it lacks those last elements that makes analog reproduction sound real, not reproduced.
Franz in Florida
best regards,
Mike
Hi Mike,
I don’t know. My agent who is a dealer for SAT in Thailand told me.
I was interested in Telos at one point because I was interested in a dd and thinking of copying your tt setup. But the sapphire version of your arm was wayyyyyyy too $$$$$$. I figure if I can’t go all the way like you why bother right? That was before the AS tsunami that hit all four of us.
If you are interested in original SAT, the production is already stopped at 70. These are very difficult and time consuming to produce. New models after 70 will be in 9” and 12.” They will be produced differently. US dealer probably has inventory of old one.
Kind regards,
Tang
That many MC phono cartridges have low source impedances?Frankly I am a little shocked by the pictures. The mettalic armwand is no longer shielding the wires, which are now free to pick up noise and hum. Am I missing something here?
Although the following is a biomedical link, the same principles described here apply to audio.
https://www.biosemi.com/faq/shielding vs active electrodes.htm
Further, some degree of noise cancellation will be conferred by the twist applied to the headshell wire harness.
However, if your cartridge is a higher-impedance MM or MI, shielding over the wires may be necessary to avoid noise pick-up.
Hi David: As you have surmised, the tonearm is a mongrel of various parts pieced together . Note that all excess parts that could resonate and color the sound have been stripped off. Only the essentials remain.Hi Jonathan,
Really good to see you here, came looking for you & Stig at CES but was told that you didn't come this year.
What is the tonearm, looks like a hybrid M2-R?
