Audio rack
alfa100, yes the HRS rack works well with the MSB stack. A home demo would be awesome but be aware that the rack I ordered weighs in at over 300lbs when the shelves are installed so your dealer has to be willing. Let us know what you think if you get the chance to audition at home.
Hi,
I am on the lookout for a audio rack and have been reading up on HRS/FE/GPA. I have currently on order the customized HRS M3X for the AMG Veilla TT but the top of the line HRS rack is prohibitive! And so are the FE master refs.....the GPA Monaco seems kind of reasonable, on relative terms, and I have heard good things about them.
Appreciate some specific feedback on the GPA from users on this forum.......believe Jfrech owns one as is evident from his signage. Also, a comparison with the likes of FE/HRS will be helpful.
Cheers
Sujay
Sujay
Have a look at the Critical Mass Systems racks as each shelf can be different than the ones above or below depending on what your needs and budget are
http://www.criticalmasssystems.com
The science behind it is exceptional with a patent for the design.
Sujay
Many thanks, Steve, for steering me there....I am going through their website, as we speak, and they look gorgeous, for starters! Will keep you posted.
Cheers
Sujay
PS: also looking at the Adona....
They aren't inexpensive but the science behind them is excellent
Agree, Steve, cant ignore the price tag. am writing to them to see what best I could eke out. The trouble is that there is no dealer in South Africa.....which could, OTOH, be a blessing in disguise if they agree to deal directly. Lets see.
Cheers
Sujay
Cheers
Sujay
If there is no local distributor, hopefully they will deal direct with you
Just curious: what do you think is the best audio rack out there? Anyone using Artesenia perhaps?
i've got one on order, arriving end of september
