Dude, it's working for you and sincerely I'm glad it does. You are right. Choosing the right gear is essential I believe I said that. Still I don't get why you and the other guy think I'm trying to paint some kind of picture as if I had an agenda. If that's what you think go out and say it. I'm telling you I have none. FACT is the reference voltages are widely different and that has consequences. If you do not believe me fine. If you want an answer from someone you will believe ask the manufacturers the pros and cons. I'm out.
Jinjuku,
IMHO we must separate AV multichannel systems and needs from two channel stereo - they are completely different products.
One of my first jobs was installing edit suites for both Video and Audio. I came in at the time that everything was transitioning from LE to NLE. We did a few higher end consumer installs (primarily for good sized handful of Cleveland Cavaliers).
I still don't know how an XLR or RCA, a Speaker management system, a processor etc knows it's in a consumer or business environment. We were the guys paid to figure it all out. We did everything from Crestron to Extron, AMX(Panja). It all worked equally well for home or professional installs. Did a lot of Hafler for both also. Speakers are where there are much clearer lines of demarcation. You don't need a line array capable of 105dB 80 foot out in a house
I agree there are signal level differences and I have to ask when used in a consumer environment: So What? We chose gear accordingly. Again it was what we were paid to do. You said I should contact the manufactures. We didn't need to: We WERE the pro's.
My DCX has Analog to Analog noise floor of 112dB, channel X-talk -70dB. And that's for entry level gear. I can use it balanced or single ended because it has enough gain structure to do either. It is what it is. Why are you so stuck on this non-problem?
Jinjuku,
Your unit does -15/+15 you do realize it does this in digital domain prior to the output end and that going down from +10 to -4 in this manner shaves off around 5 bits don't you? It would be a non issue if you simply swapped out the analog input and output stages which could be as simple as a few inexpensive op-amps and supplies to attain -4 spec. Well for you it's "good enough" and maybe it is FOR YOU subjectively. You could even do something as simple a band-aid as adding individual attenuators to adjust output for -4 between your unit and the consumer amps if they don't have built in attenuators like your Parasound did, a fixed pad even, so you need not sacrifice any of that -112dB as you shave bits while avoiding clipping distortion on the amp input side. No, you choose to just use the internal output controls. Based on your "good enough" standards, I would not hire you. You unknowingly dumbed down your own kit which was fine as spec'd. Congratulations.
None of this, NONE, would happen in an all +10 system. No needed modifications, no band aids, no performance sacrifices. None of this would be a problem if Behringer, Lake, et al would simply provide -4 options, fixed or switchable for use with analog sources on the inputs and amps on the outputs.
Look at your post #104 and do some fact checking. That post is telling.
Ok. You have my attention and I am listening.
This was a discussion on mixing +10 with -4. While you segue to all +10. Cute way of agreeing with me while saving face. I'm the one with reading comprehension problems? Sure.
A connector does NOT make a -4 a +10 and vice versa.
The 6dB drop for balanced to signal ended is also not a result of your processor making "automatic" internal adjustments. You are simply using one positive instead of two. Besides you need to be dropping approximately 10dB not just 6 to avoid clipping.
The stereo experience, due to the intrinsic technical limitations of the system, is strongly enhanced by a controlled use and tuning of the "small differences". The palette given by professional equipment is not large and systematic enough to create great audiophile systems for consumers. AV multichannel systems carry much more spatial information, and are much more predictable - here the professional units can easily outperform consumer units.
As F. Toole once wrote, stereo is an individual experience. Many people share his opinion and regret that the music industry did not fully endorse multichannel, going on supporting the two channel format. Just my opinions, YMMV.
No this was a discussion about how you are convinced that Pro-gear some how has a higher noise floor. Remember you are the one that brought up the ambient noise floor of a live venue vs the home and try to in some ignorant fashion relate that to 'noisier' gear.
I shudder to think how many setups of yours I would have to un-knot. I've certainly had jobs cleaning up after management. That's actually what convinced me to hang my own shingle. Had one boss run the business into the ground. Took him 18 months after I left. I get a call from a head hunter years later. It's my form boss looking for a job.
This was a discussion about how Pro-gear somehow isn't 'consumer rated' with it's +10dBu rating.
[sarcasm]No WAY! Really? Wow and all this time I had it wrong [/sarcasm] Now you are just laughable. Find a post where I said a connector makes a signal rating. Crown on the XLS drive core has RCA. Guess what: It's not -4.
Typically TRS, XLR, Balanced Phoenix connectors are +10. No one ever said they would be. You simply have to know the gear.
I'm not the one that ever mentioned signal format mixing, bump boxes, pads, op-amps etc... Someone that thinks hacks are somehow the norm did.
So is the DCX doing this in the analog or digital domain?
On one hand you are saying it does it in the digital domain (so automatic internal adjustment) but you also said it's single ended operation is not a result of automatic internal adjustment.
So is it simply less voltage output or are 5 bits being shaved off?
![]() | Steve Williams Site Founder | Site Owner | Administrator | ![]() | Ron Resnick Site Co-Owner | Administrator | ![]() | Julian (The Fixer) Website Build | Marketing Managersing |
