Is it 20x5mm size?
just to headfcuk you some more i think a AMR GOLD fuse would be better on your pre, i did not like it but it did bring body. the ref 3 can be a bit thin. do the sr red thing and see how you get on bill, there is more to be said lol but lets see how you get on with these first
the SR RED do seem to take a little distortion out but weather you llike the rest of what they do is up to you m8.
yea monolayered because a artist cant paint without a canvass.. ok!?
or better still without a muse... and whos fault is that?![]()
Cheers, Spaz. Will give it a try and see what happens. My GG has loads of body so not really wanting to fatten in up any more per se. I am a 3D head though so if it brings any more of that and resolution, then I wil be happy enough.
Well I put a Red into the GG and burnt that in also over night. I am seriously impressed with what they have brought to my system - I would describe it as increased purity - I am getting more resolution, deeper soundstage and a layer of grain removed. I am hearing more of the acoustic in the classical venues that I have been listening to. Great stuff and highly recommended.
Bill are comparing to the stock fuse ? I have rolled my gear with the HiFi Tuning Supremes , so wondering if the Red's are a step ahead in comparison . Cheers
Which value are you using for the GG dac fuses Bill? And slow blow fuses?
Btw, Synergistic Research is on the brink of launching a new top of the bill fuse called Black. Apparently it is clearly better than their Red fuse as it should be because the price is 1/3 higher than their Red fuse.
