What’s two weeks between an audiofool and his fuse?
You should pity me, I’ve just done a wholescale analog reinstall needing over a dozen seperate new things to break in.
For the stylus, energiser and psus, I had to go thru 240 sides of the same lp (on mute, being careful to not once forget I had an lp playing and allow the stylus to get stuck in the lead-out groove), to start to get where I am now.
Pure torture.
This is a fascinating thread, very illuminating and bidirectional.
Francisco,
I need no more stress in my life for the few remaining years I have left.
I have found that fuses are usually stressful. When we have to replace them it is a signal something went wrong. In tube amplifiers usually it is just one tube - either you have a tester to check for each of them or you have to create a strategy. I successfully tried an alternative method before taking serious action - I replace the fuse with one of much lower rating, say one fifth its advised current, darken the room and switch the amplifier on in the dark, looking at the tubes. If I am lucky the faulty tube glows when the fuse blows!
Hi , Bazelio didn't I just read your review on the new D4 IC" Plus you stick in a new SR Blue fuse. I think you are now doing the right thing and letting the fuse burn in and letting the new D4 burn in then get used to the sound before making your final decision.
Awfully difficult to give a fair assessment when you have changed both IC and a fuse in a system at the same time and it doesn't sound right.
Enjoyed your review of the D4 by the way and hope to get a pair myself soon.
I must have mist the broken in part on the review, my mistake.
I currently have 45 hrs on my blue fuse and I read this thread before purchasing it so I new there would be a break in period. It certainly better then the stock fuse it replaced. It certainly sounds better then the first few hrs.
I had the blacks last year in a different system and liked them thats why I wanted to try the blue.
Very Good & Brilliant.
zz.
Well I might be a fairly lonely voice of dissent here in regards to the SR Blue. Last night I replaced the stock fuse in my EAR 890 with a brand new 4A SR Blue, and I am decidedly disappointed. People have told me these are supposed to sound good right out of the box, so I don't know if I should give it time. But the SR Blue sounds distant and compressed vs the stock fuse. It lacks the air and openness of my stock fuse, it truncates decay and mutes treble shimmer, and is a tad bloated and less articulate on the bottom end. Kind of a thicker and slower sound that's less extended in both directions. So overall not a good showing. In fact, it didn't last more than one side of one record before I said "meh" and went back to the stock fuse.
Should I expect dramatic improvement here, or should I send it back now? I hardly have the desire to sit around waiting for it to improve, but could be convinced to reconsider.
EDIT: On the positive side, the SR Blue is a bit quieter than my stock fuse. But the slightly blacker background is probably related to the slight veil over everything that has been introduced.
Thanks!!
Should of included I have 176 hrs on the blue fuse.
