Fuse was no different from stock one in my Lumin U2. If anything, I prefer the stock fuse from samples that I recorded but I forgot to disable damn auto record level on my Zoom mic. So in amplifying the files, they don't look exactly the same. I don't think it was the difference between the fuses though. It was operator error in the process. Either way, I heard zero difference after spending 3 weeks with the Nano Fuse.Attaching screen shots of the samples in Audition.
I don’t know anything about the entry level AM fuse (vs. further up the line). I assume you gave the Nano fuse at least 250-300 hours under power before comparing. I wouldn’t worry about measurements, but how your system sounds to your ears with each.
