In an effort to decide whether to install several more Sonos Play 5s or to install MartinLogan Edges (in-wall speakers) or Vanquishes (in-ceiling speakers) I decided to conduct a simple A/B/C test.
This test turned out not to be so simple. First, the Edge sounds dull and muffled. I think something is wrong with the ribbon tweeter. So Crutchfield is sending me a replacement Edge.
The Vanquish sounds clears but lacking in lower midrange or bass fullness of any kind. (I also turned up the bass all the way on the Arcam A90 integrated amplifier I am using for this test.)
So far the Sonus Play 5 (which we have been using for several months) may not be as clear-sounding or as transparent as the Vanquish, but it sounds much fuller and richer. I am beginning to think that the Sonos DSP adjustment the Play 5 makes when you install it really boosts mid and low frequencies.
