Due to my age and ear sensitivity I can only listen to music at 50-55 dBS with intermittent peaks at 60-65 dbs. My current system consists of the following:
1. Martin Logan 11A impressions hybrid electrostatic speakers
2. Bryston 4B3 Cubed power amplifier 300./channel into 8 and 500 into 4 ohms.
3. Bryston BP-19 preamp
4. Chord Qutest Dac with LHY linear power supply added.
5. Lumin U2 mini with S Booster linear power supply
6. Pair of SVS SB-4000 subs
The problem is that at this low DB level the sound is mostly thin and is not full sounding. In order to achieve full dynamics, I need to listen at 70-75 DBS which causes ear discomfort.
I am planning the following upgrades:
1. Purchase of Weiss 204DAC (will listen to next week) If this works will purchase and then add a linear power supply. Linear power supllies make a positive difference.
2. Purchase of Schiit Audio Loki Max, which is an equalizer. Will boost bass and treble to
effectively use the equalizer as a loudness switch to counteract the Fletcher Munson Curve.
3. Hiring an acoustic consultant to make sure my room is maximized acoustically. I know about bass traps, absorption, diffusion, but I believe it is better to bring in an expert who after objective tests of my room can recommend treatments and the placing thereof.
4. If all of above do not work for me I would replace my speakers with possibly open baffle,
horn speakers or one driver speakers. This would be my last resort. Any advice would be appreciated. I am hoping there are members that has the same or similar concerns as I do.
Thank you for any advice. Just purchased the amp and preamp and not my preference to
change. But I am open to listen.
