Hey guys,
Can a Alps Blue Velvet compete with stepped attenuators regarding sonics?
Sure. Plenty of fine preamps using ALPS BV pot. Of course there are stepped attn preamps that are equal or better. As the cost goes up you see more of the hand matched volume components.
So stepped attenuator are always superior?
It depends on the attenuator. A silver alloy Shallco in a shunt or ladder configuration using the best sounding resistors just about slaughters any mechanical or electronic pot.
Very few commercial devices use attenuators of such quality. Remote operation is difficult and expensive, the cost of resistors can quickly mount once you realise 40 or even more steps are essential. Even getting the desired resistor values is far from trivial in really high quality resistors.
And this is the reason some manufacturers choose a $2 electronic pot, carve a case around it out of a solid alu block and plaster a "Reference" designation in front![]()
Yeah true but you think in a blind test people can tell the difference between Shallco and Alps Blue velvet since tube preamps have lot of distortions anyways?
Hey guys,
A key issue with volume controls and switches is that the signal has to jump across the contacts or wiper of the control. This includes poteniometers, stepped attenuators, and switches. The impact becomes progressively higher as the attenuation increases. Of course, implementations and parts quality vary, but the only way for the signal to avoid having to make that "leap" is to use soldered connections.
I use a Totuga controller that implements hard soldered light dependent resistors (LDRs) to perform attenuation as well as other functions that would otherwise require switches such as selecting between inputs, choosing between various input impedances, and even toggling absolute phase (which varies from one recording to the next). My Tortuga LDRxB does all this using LDRs with all functions available using a standard Apple remote.
The Tortuga has full bodied bass with great extension to the lowest frequencies. Dynamics, soundstage width & depth, instrumental timbre and coherence are all there. I've seen it better five figure preamps & controllers. Worth taking a look at www.tortugaaudio.com.
Hi flm09,
Tortuga has various controllers. active preamps, tube or solid state buffers , and standalone LDR volume control packages that can be implemented in other units such as your DHT 300B preamp. One more thing, I'm running my LDRxB from a 12V battery. Tortuga offers a battery power supply or you can easily make your own-- I use an Optima marine battery and a trickle charger which is way overkill, but still cost effective. Morten Sissener of Tortuga is great to work with.
Best,
Robert
I still recommend that you try a Tortuga (Morten offers a 30 day trial). I think you'll be surprised and that the price is a bargain. I'm using the LDRxB in a system with a Lampizator Pacific DAC as input. The Tortuga drives a biamped pair of Von Schweikert VR100XS speakers. A pair of Lampizator Pacific 211 monoblock amps drive the mid/treble and a pair of Spectron Musician III Mk2 amps as monoblocks drive the bass.
Robert
Not sure what distortions you have in mind, but if it's about harmonic distortions I can assure you it is not a lot. 0.02% thd is easily achievable even without nfb. And even if that is a lot, why should it matter? I cannot imagine anyone in this hobby not hearing obvious differences like that.
Ironically, the very well regarded LDR attenuators are distortion champions, at high levels easily eclipsing tube harmonic distortion.
Oh I didn't know that! So sticking with Alps blue velvet is good enough?
It's fine for the price, a high quality stepped attenuator is much more expensive. IMO it's worth the cost, but the choice depends on budget and expectations.
