Burmester 878 help
Dipdip
1
Hi I was hoping to get some advice . I have a chance to
get a Burmester 878 amp and was wondering if it has enough
Power to drive a set of Energy Veritas 2.8 , also wondering
if they would be a good match if amp is powerful enough .
I am under the impression the 2.8 s are 4 ohm and minimum
recommended power is 70 watts . The preamp is available
and is an 897 . Any thoughts or input appreciated
Thanks
Here's the 878 specs.
Effective output
stereo: 100W + 100W (4ohm)
mono: 272W (4ohm)
Peak output
stereo: 200W + 200W (4ohm)
mono: 544W (4ohm)
Input sensitivity
880mV (balanced connections unbalanced connection both)
Input impedance
10k? (balanced connections unbalanced connection both)
SN ratio (vs. 5W)
-96dB (Balance when connected)
-87dB (unbalanced connection)
Frequency characteristic
5Hz ~ 170kHz -3dB
Total harmonic distortion
0.009% (5W)
Intermodulation distortion
0.04% (5W)
Rise time
2.8?sec
Slew rate
18V / ?sec
Damping factor
400
External dimensions
98 × depth 305mm height width 51
