Choice coaxial cable 75 Ohms for realization clock cable D.I.Y
I have the Harmonic Technology DC III 50 ohm Copper cable with BNC termination which I liked a lot. The limited information that is available on these cables suggests the silver is supposed to be better. I bought mine from these people and this site appears to be for the Digital Silver cable but Google isn't automatically translating it for me so I'm not quite sure what it says.
labkable.com
You could save quite a bit of money DIY'ing the cable although I have a vague recollection that BNC connections at least are supposed to be finicky. MCRU is the only place I've seen bulk cable. And The Cable Co is the only place in the US I've seen finished cable. https://www.thecableco.com/digital-silver-iii-digital-cable.html
If you do go the DIY route and are confident you can do a good job let me know. I might buy one from you. I only use a 75 Ohm cable with my EtherRegen and have only used cheap cables there and it isn't clear to me if more expensive cables with that device make much difference.
Bonjour
Merci pour votre retour, j'ai passé une commande effectivement ducable sur le site MCRU et cartes BNC chez Aeco, je vais le faire moi même, mais j'en aurai juste assez pour moi
Étant donné que le Royaume-Uni est en dehors de l'Europe, il est soumis à des restrictions en matière de TVA et de frais de douane, mais je verrais bien...
