They are German...cant be a Patek. Maybe a A. Lange & Sohne.
True, Patek the KING is Swiss! Ha!
Do you live in Switzerland?True, Patek the KING is Swiss! Ha!
Are you a Patek owner? I used to collect them when I was younger. In fact I sold my collection to open my first audio shop.
I'm sorry but I don't know what that refers too. That would be a question for Oliver Gobel.I prefer Vacheron to Rolex myself, stylewise. ...but I take your point.
I know Gobel makes jewelry, don't worry. So does Dart.
I think you didn't get my joke. The tag line for Patek is that ones does not own it, you merely guard it for succeeding generations. Thus I have never even been a guard. LoL
Is this the same bending wave tech from Manger?
http://www.mangeraudio.com/en/discover/about/the-manger-sound-transducer
and
http://publications.lib.chalmers.se/records/fulltext/154618.pdf
I will get the infor from the 2nd article.
Tango,
Elliot just delivered to me speaker cables, USB and a Power Cord. He hasn't yet heard it on my system as I have been burning them in for the last 4 days. We are going to have a listening session tomorrow.
Let me say that as to build quality, there is NO equal on the market today. They are truly a work of art.
As to sound, I will give a more formal opinion when I believe they are at their best in my system. Relative early impressions are "remarkable". The Gobel cables are replacing my Valhalla 2 for reference.
My speakers are the Nola Concert Grand Golds, for reference and my DAC is the MSB Select II, for reference.
Howie
Hi Priaptor.
What is your experience respect the Goebel Power cord?
I have an USB one and next week i'll recieve the Ethernet.
Now i'm testing a Vertere HB power cable. All the rest are Siltech. Emperor ii, Empress, RMii, Octopus,...
I've been aware only putting the Goebel PC on amps.
Have you connected it to your Select DAC? Coming from Nordost it seems a big different change.
Regards.
Thanks for your answer.
It couldn't be more convenient.
I need it to my Esoteric D02X Dac or my TADC600 preamp.
I don't know if you are using the Select as Pre too.
Even i would try it on my Wadax Atlantis Server.
Are you using the Ethernet one too?
Power cable is the most important cable to me. Specially on sources.
If i'm not wrong, the Select is on the warm side, so if Goebel is working fine i can expect the same on my system.
Respect Furutech, i saw it. All my connectors are Furutech Rodhium/NCF.
Hello Wisnon,
Many thanks for your question.
Our bending wave technology is totally different to the Manger technology.
Our patented Carbon Excellence Bending wave driver is a “stiff” bending wave loudspeaker and the Manger is a “soft” bending wave loudspeaker.
On the first sight, this doesn’t sound like a big different, but it is a big and fundamental difference, which lead to the advantages specified in our technology section.
Elliot was so nice and already liked in his last post the technology section of our website in this forum. Please follow the link and you will understand more of our unique solutions.
All the best,
Oliver
Hi Priaptor.
Regards.
You describe the sound as "spatial detail".
I have reports that bass improvement is the most evident.
I think you are reffering to a better midrange aperture. Don't you?
Could you elaborate it?
I think any changes on you Select will be bigger compared to the amps.
I tried Goebel PC, Siltech Double Crown, Siltech Triple Crown. The Double Crown used to be my regular until now living with Tripple Crown. You mentioned you use the Double Crown pc. Goebel PC has advantages over the DC. Transient speed is better, energy transfer is better, denser and quieter with “black” background. It also expands sound making image size larger than the Siltech. One might be deceived of having bigger sound stage. When you demo it, your first impression will likely to satisfying. Try to live with it a few days and see if it fit your preference. Logic will tell you to stick best pc to amps. Although I am not much into digital, what I have seen most of the times excellent pc yield biggest delta with dac.
Kind regards,
Tang
