Digital was originally sold as the "convenient" medium, among other things. But look around at what's available in the market, and it is a FUGLY morass. Talk to a dozen guys and get a factorial of several dozen of suggestions.
Even a TAS writer got confused and had to write an apology:
http://www.theabsolutesound.com/articles/comparing-sacd-to-a-dsd-download-a-follow-up-report/
Windows vs. Apple? River vs. Itunes vs. proprietary? SPDIF vs USB? DSD vs PCM? Upsample to how many times of DSD? Meaningless buzzword vs. Marketing Buzzword? Etc....
What sounds like MUSIC vs. a 10 digit-priced, highly resolved digital robot?
And as soon as you settle on something, things change!!! Buzzword A is so much better than Fuzzword B ....
So is Computer Audio just for bored computer nerds who like to play around with settings and rip files? Personally I want to just kick back and listen to music!
Seems like dropping the needle in the groove or popping a cd into the transport is much more convenient and musically satisfying. Is this really about the music or letting our bored, inner nerd play around?
How do you separate the engineers who deliver analytic sound from the "Golden Ears"? How do you know the engineer is correct? How do you know the "Golden Ear" is not selling you something?
Who do you trust with understanding the options so you can make the right choice? Or do you just not bother at all, like me?
I don't know what kind of software you guys are using, but I put in the disc, it rips, adds the metadata, categorizes the files (every once in a great while I disagree and change something). I type nothing. I search for no metadata. Nothing is required of me except to wait 10 minutes while the software does the work, then listnen to the music.
Like I said, you can make it incredibly complicated if you want to.
Tim
My PC switches sample rates automatically
Hum, audio is part of the USB standard from 1998 on.
Complicated?
Wonder how the average consumer will deal with this
An easy solution is a file player like the Bryston BDP-1/2 or the Auraliti PK-100.
Did you build and install your server software ?
I was about to brag about how easy Jriver is to use but then I got this message when I tried to update it today.
I uninstalled Jriver and reinstalled it. It's easy to restore the library and all setting though since it auto saves settings daily.I had the exact same dll error a few days ago. Tried uninstalling jriver and got another dll error. Fiddled around with it trying uninstalling and reinstalling stuff, and at some point it came back up. First thing I did was disable automatic updates in jriver. It is infuriating.
Me also. I has to restart the computer and uninstall and then re-download. This happens every time Jriver updates. It sucks but I am sure there aren't ever any maddening technical problems with turntables, right?I could not uninstall jriver because of another windows dll error.
the biggest problem is I have no reason to even move at all. is that a problem?![]()
