I'm curious...
How does the CS Port LFT compare to the J Sikora Reference Line table?
Which is your favorite arm and cartridge on the J Sikora Reference Line table?
Thank you and best wishes,
Don
Both CSport and J.Sikora, in my opinion, are excellent turntables.
In my observation, the J.Sikora has precise start and stop capabilities, and when used with the AnalogMagik Software, it maintains speed stability with a tighter tolerance compared to the CSport motor. J.Sikora appears more authoritative, and its bass and mid-bass delivery are particularly impressive, akin to the way my Technics SP10 performs but with a more musically pleasing sound. On the other hand, I found the SP10R to sound a bit too aggressive.
Furthermore, J.Sikora stands out as an exceptionally quiet turntable that doesn't require additional equipment like airpumps or clamp systems. I find its setup process to be easy and hassle-free.
The J.Sikora turntable possesses refinement and directness, making it adept at presenting pop or more modern-day music with a great sense of pace and rhythm. In my opinion, when set up correctly, it becomes an incredibly musical platform. I find it versatile for various genres, and setting up arms or multiple arms is effortless.
On the other hand, the CSport has a slightly more refined and sweeter sound, with a touch of agility and smoothness. However, it sacrifices some low-end response compared to what the J.Sikora can deliver in larger spaces. Nevertheless, the J.Sikora can easily match the slight advantage in the midrange to upper range, depending on the arm and cartridge used.
Both turntables are indeed excellent. However, the CSport requires some time and effort to achieve better motor system stability and speed stability. Fine-tuning the airpump flow to both the arm and table is necessary to get the best sound from it. On the other hand, the J.Sikora is much simpler in this regard, as it offers a "plug and play" experience.
Personally, I find that the J.Sikora is better suited for my preferences in music genres like Pop, Rock, Electronics, Hip Hop, and Movie Scores..
I prefer the CSport on Classical Musical and Jazz and certain vocal or soft music. Its refinement and sweet sound can sound a little too soft on certain recordings. Its hard to choose which one i would pick as first. Depending on the music i switch tables often.
