My biggest safety concern with horn speakers and super tweeters is protecting against unexpected peaks in program material. My room is 20 ft x 11 ft-then across a 4 ft wide hallway and into a 9 ft x 8 kitchen. A triangular ceiling that peaks at 11 ft is above everything. I plan to sit 11 ft from speakers with mid horn/driver and tweeter like these, but minus the back loaded horn. https://josephcrowe.com/products/speaker-system-no-2095
These woofers playing down to ~ 55Hz.
Below those I have two or three of these subs to use. https://www.rythmikaudio.com/F12.html
All music sources and movies (DVD, BD) are pc-based, with JRiver being my primary Windows player. Whether I use a stereo or DAC to first measure and correct the room acoustically as best I can-or then attempt further correction via a MCH DAC (e.g. https://www.merging.com/products/interfaces/hapi )-I was assured by Hapi users that I can control master volume and mute via a wireless Windows keyboard.
Having a lightweight keyboard on my lap for volume/mute is one thing, but it's those split second SPL blasts from movies, that all too often crop up in movies that can hit your ears, which literally terrifies me-as it should anyone who values their hearing (??!!). So, what's the best solution to provide instantaneous protection against dangerous SPLs while preserving audio quality (resolution)?
Some kind of limiter plug-in?? What would be best? But how fast and precise can it limit SPLs? And what sonic penalties might I pay for using it?
