Mine is slightly different.
The SPU version is the heaviest of the 3 and employs the most ebony and brass. As far as its voice, the SPU has the greatest range, dynamics, soundstage and tonal balance.
Are the Tzar carts still available out of Russia?
I am interested in this cartridge. I have the OMA Anatase with Schroder TA. I now have the option of adding another tonearm. Should I add the DaVa to the Schroeder or get another arm. What would best complement this cartridge?
As great as your Schroder is, I think it is the wrong choice for the DAVA. The DAVA is 26 grams so, I don't believe the Schroder's effective mass is high enough to compliment the DAVA. I would ask Frank his opinion.
I already have the Schroder tonearm. I am not sure I want another Schroder arm. I prefer to get the tonearm that will work best with the DaVa unless my Schroder BA will fit the bill.
Got it! I have a couple Glanz MH-1200S tonearms. They work perfectly for high compliance cartridges and seem to be a great match to the DAVA, Tzar SPU DST and my Ortofon SPU collection.
Anything that you could beat an Orc to death with should be just fine …. Viz FR64S or FR66S
Reactions: svenjosh
You should query Darius. He could probably provide a list of many different tonearms that have successfully been matched with the various DaVas. The cartridge weight is one major factor.
I had an Acoustical Systems Aquilar--a great tonearm--but it didn't play nicely with the DaVa, even though I had all the necessary bits to deal with the cartridge weight. There was added distortion on some records. Currently I am using a Viv Labs arm, and I am not the first to do so with the DaVa. I am using it with a pod supplied by Mike at Sierra Sounds, the US importer for Viv Lab. The pod is smartly designed, and makes adjustments to the Viv Lab much easier--the bete noire of that tonearm. The Viv Labs arm really sings with the DaVa on it.
that’s a nice system with the Devore. Guess you have space around them?
I always thought acoustical systems was a meh arm as well their Palladian cart. But interesting to know Viv can manage Dava.
I reached out to Darius.
Reactions: High Water Sound
Thank you! Yes, 8 feet to the back wall and 5 feet to the side wall.
Reactions: bonzo75
At last the EMT 997 Banana AB ( Alfred Bokrand ) black edition is mounted on the 927! Wow!
Alfred has made it possible to swap between DaVa ( why ?? ) and ”normal” SME type cartridge. It sounds amazing. Great combo!
How is this comparing to your other arms
Compared to the Ortofon Banana 12-inch this arm uses a spring to adjust the needle pressure and I think it sounds more transparent and extended in both ends.
Alfred claims the black color reduces resonances better.
Reactions: bonzo75
DaVa is here after a, punctual!, 6 months wait.
Had issues with the first batch, possibly due to a mishap on my end.
Got the full service from Darius. Extremely communicative and helpful. Wonderful customer service.
Now breaking-in, and sounding very promising from the first notes on my JN Lenco with the Ikeda.
