From Kara Chaffee, posted here with her permission:
Hi Brett,
The heads in the 10-20mH realm are too low for the 222. Most other heads are 150mH and up, which work fine. I have customers with Flux heads, but you should verify the impedance of the ER head. The 222 uses a really special bipolar op amp as a head amp --then that couples to two 12AX7s , and they are coupled to a 5687 tube cathode follower. The tube sections are fed from a 6X4 tube rectified power supply. I tried to keep as much as possible to the spirit of the Ampex 351 , but you just need more gain than the basic 12AX7 can deliver.
Sincerely,
Kara
I'm guessing the OP amp she is referring too is the Muses02, can anybody confirm this?
So there you have it, I traced out the circuit to find out what I know about it - I'm a nerd. She also uses Russian K40 caps in it coupling over the op amp to the 12ax7s. This may be a source of consternation as well. The Russian caps are well liked in the DIY community - primarily for their price- although the price advantage has changed lately.
If I get the interest I will change out the caps with some of my favourites one day to test the difference. In the meantime I make progress with my own diy all tube design.. it will be ready one day . Maybe better maybe not.
