Din or RCA output?
The cartridge operates with a low signal voltage. The more contact points there are, the more potential for error. That's a fact. If these contact points are cleaned regularly, there's nothing wrong with that, but I decided not to.
If it is possible without completely disassembling the tonearm, i always recommend continuous cabling.
Good sound kit
Sure I suppose one can cut off the pins and solder it up…
They seem to sound fine with the various colours of tonearm cable just slid on though.
There are fighter airplanes, spacecraft, deep sea vehicles which all have connectors coming out the ying-yang, and they all seem to work just fine. Maybe they are more digital now. Even the Glomar ran power and video for miles on their cable harness.
Sure a cartridge motor generates a tiny signal, but gold plated pins and female connectors seem to be making good connections.
This usually takes an hour. To do this, unscrew the DIN plug, cut the cable directly behind it, solder the new cable there and solder it thinly; thick areas prevent the new cable from passing through. If you have a replaceable headshell, loosen the lower screw on the bayonet catch, then pull the new cable through the tonearm using the old cable. When soldering at the bayonet, insert an old headshell and solder it on using a short, strong heat. If the heat is applied for too long, the spring contacts inside will no longer work. Then fit a strain relief (made of bronze in the kit), either using the screw from the DIN plug or with drops of glue. 20250727_162845.jpg
The continuous wiring is complete. Without a replaceable headshell, I would use the pickup plugs from Clearaudio. They are made of direct gold-plated copper and their shape ensures a secure fit.
This cabling was clearly superior to my previous AudioQuest Leopard PhonoCable(900€) in terms of sound. If you're happy with the sound, I wouldn't change anything, but there's a lot to improve.
P.S
You don't want to really compare connector quality with aircraft and high-end audio. They use connectors like Lemo and Tuchel, which are worlds ahead of the audio in terms of contact reliability.
Are you saying that a copper to solder to copper connection is superior to a gold pin to gold socket connection?
Your gold to gold pin conection need a solder conconection at both ends. I have no conection resistance at this point at the tonearm who wins;) think about it.
Reactions: mtemur
I’ve rewired a few tonearms from various brands. If done properly, rewiring can bring significant improvement—but it’s crucial to ensure that none of the bearings or related parts are disturbed or removed. In many cases, it’s extremely difficult to rewire a tonearm without affecting bearings or support components that were torqued at the factory. I remember feeling like I was going to have a heart attack while rewiring a couple of Thales Statement arms.
You often read comments like “the soundstage opened up” or “detail level increased” after a rewire. While those may indeed be the result of successful rewiring, they can also indicate loosened bearings. The real key is the bass—if the job is done properly, the bass should be strong and firm. The best way to check whether the bearings were disturbed is to compare before and after using the resonance track in the AnalogMagik software.
If you’re not absolutely sure what you’re doing, don’t attempt to rewire your tonearm—chances are you may ruin it. Personally, I don’t buy a rewired tonearm unless it was either rewired by me or by someone whose work I trust.
Reactions: DasguteOhr
Here rewire, check and tweak what you want
Reactions: dennis h
