Hi guys, my setup is red wine Isabella tube pre , spectral dma180s2 , plinius cdp 101 , Von schweikert unified 3 speaker, using asi liveline interconnects and analysis plus sc for tweeter n yter sc for bass module of unifield 3. In audiogon, it has been discussed that u need not use MIT ic if not using spectral pre.
I understand not using MIT sc might cause the spectral power amp to oscillate , eventually burning the output stages. I been using the power amp for a few days with no issue except the rubber feets starting to melt and I hv removed the feets, replacing it symposium roller blocks.
Could u advise if I still need MIT speaker cables and ic? If yes, could a kind soul recommend the model? Budget less than 5 k for 2nd hand MIT speaker cable. Is 850 cvt ok? Oracle model seems not compatible with dma 180s2?
Sorry I'm a newbie so asking loads of qns
