Hello,
I use Spectral DMC30/DMA 360 with an "old pair" of JBL K2 S9500. Some people consider that these speakers give their best with biamping.
I also have in stock 2 DMA 80M (mono version of DMA80) and if I find a second pair of MIT cable, I will be able to test this schema.
Does someone know if these both amps have the same gain? I found nothing on Spectral website.
And about the DMC30 output, will I have the same level on RCA and XLR?
If noone know, I will test it by myself and report the results here, but it's not so easy to dismantle my system for this kind of tests.
Thanks for all
Regards
Ugo
Thanks for all
Regards
Ugo
