I am getting a J.Sikora Standard Max turntable which has a very tall platter and I'm trying to find a stand mount for a DS Audio ION-001. My thought is the stand base would slide under the table and then have fine adjustment for height and distance from the record.
Something like this but I need more of a clamp attachment to hold the ION-001.
Probably over engineering this! LOL
RK-06AE - Dino-Lite Digital Microscope | Americas
The Dino-Lite RK-06AE tabletop stand with ESD protective base designed for general purpose, smooth focus adjustment and quick vertical movement, the RK-06AE eases the task of focusing when using Dino-Lite microscopes.
www.dinolite.us
