I won't get into the whole cable debate here, but will say with my 2-channel system these made an audible difference in the high end.
Could you tell us a little more about the cables? I haven't run across them in my audio travels
These are gold plated solid silver core. Two runs per cable covered in a tube of PTFE insulation / two cables per side. They have a resistance of only 0.0033 ohms/meter. Spade terminals are gold plated copper. Not something you want to move around much, but if your system is stable, these work well.
Are you saying they're stiff? I have really come to hate stiff cables because over time, they really put a strain on the RCA connectors, etc.
What do the cables retail for?
"Stiff" is a relative term. I guess you really need a reference point. These bend and form easily being a precious metal. Not to be compare with 12awg copper romex or some Maple Audio Whisper solid core cables I had that were difficult at best to bend and use.
retail for around $1600
