You won’t believe how much SQ improves by pulling off the plug of refrigerator. Sound becomes more relaxed. Down side is you forget to plug it back and waste the food inside refrigerator.
^Well you’re right.^ it is unbelievable.
It is either some expectation bias, or it is real.
If it is real then it should be able to be proven to be real..
Unplugging switch mode power supplies like tv, computer etc also help. Switch mode power supplies introduce noise to AC line but refrigerator’s motor must be doing something worse cause it made the biggest improvement when we unplugged it.
Maybe an oscilloscope is what is needed?
Unfortunately having 3 phase electricity, dedicated line and phase for audio doesn’t change this situation, at least it didn’t change in our system.
Where in the AC do you believe that the AC might be getting the noise in?
There is the live, neutral and ground.
The last two are generally tied together at some point, and the whole dedicated circuit is tied to the rest of the circuits in the main box.
And then all the other fridges up and down the streets are tied to each other via the poles.
So it makes sense that a dedicated circuit would not really do a lot to help.
If the power supplies in the components are not filtering out the noise, then that points to less than adequate design of those pieces.
If there is noise being introduced by the fridge, then have you considered a choke of some sort on that appliance?
