Fellas! Show me thy Cellas!
Great sounding video!
What size room is needed for these speakers to sing?
Best wishes,
Don
Don, What you are viewing and hearing is Stavros Danos’s test system placed in a very spacious and semi open area with the Aries Cerat design , development and manufacturing facility In Limassol , Cyprus.
Reactions: No Regrets
Hi
This was at the old shop, the room was actually quite small, about 40sqm but half of the walls were double panels designed to be "invisible" to bass.
The C are now firing in 280sqm open space (at new shop) though limited seating positions :)
I'll be test driving my new setup (mid way point of the build) with some (mono vinyl) Cello (and much more) tonight, hope I recall making a video with sound
Janosz Starker playing Bach solo Cello on Columbia
EDIT: not sure what is going on here, it sounds as if there is another piece playing at the same time....weird....
Reactions: hopkins
And more of the same but now on Period Records
Your video is set to "private". You have to set it to public or unlisted.
I set it for public, and was able to open it without problem. Maybe you hit on it before the publish time actually happened? I have re-downloaded it but only after editing to a new download time of 14:45 (hope it works now). I did publish it for children as it then doesn't have commercials, but I wouldn't have thought that would make a difference. Try again?
Reactions: hopkins
