Fidelizer 6.0 Released with big update and upgrade program
Windows X
138
52
935
www.fidelizer-audio.com
As you’re aware that there’ll be upgraded version of Fidelizer in upcoming release. However, it doesn’t decrease the quality of works I put into original Fidelizer one bit. Version 6.0 comes with big changelog fixing various issues found thorough the year. It also have some changes and improvements to be more stable and reliable. If you enjoy good sound from Fidelizer and want more for the better, consider Fidelizer upgrade program to advance your computer audio journey to the next step.
Changes in version 6.0
-Added Fidelizer upgrade program for buying advanced version of Fidelizer
-Changed ‘Professional’ optimization level name to ‘Workstation (General Purpose)’
-Changed default optimization level to ‘Workstation (General Purpose)’ for stable default configuration
-Changed some core optimizations to supported values according to Microsoft documents
-Fixed multi-core optimizations not working properly for audio playback part
-Fixed Fidelized audiophile player playback stability and compatibility
-Fixed JRemote and few others apps not working in Windows 8.1 using Extremist optimization level
-Fixed some Network Streaming optimizations that worked on unchecked one instead
-Fixed uPNP not working using Extremist optimization level with keeping network services
-Fixed some errors in parsing system configuration
-Revised core optimizations improving compatibility with all optimization levels and network streaming
Info and Download: Fidelizer 6.0
Fidelizer 6.4 Released – New website, new outlook
16500d1421549076t-fidelizer-6-0-released-big-update-and-upgrade-program-fidelizer.jpg
At last, a new home in Fidelizer-Audio.com website. Now I can focus making dedicated contents to Fidelizer and related audiophile projects since some potential customers are tormented by of ads from my original website hosting freeware projects. In new website, I focus only on what users want to read, what they want to see, and what they want to understand.
It took me only one day to build a new website but weeks later for rewriting contents over and over until it’s very easy to read and understand. If you ever have any questions about Fidelizer products or website, don’t hesitate to ask here. And also updating Fidelizer for changes to make it looks cool with new website here.
Changelog for version 6.4
Fidelizer
-Added core audio files missing warning in title bar if not found
-Added ‘Windows Management Instrumentation’ service checking before running
-Keeping some services from shutting down in Extremist is now possible without choosing Customize
-Removed setting default homepage option for less intrusive anti-theft protection
Fidelizer Plus
-Fixed unchecking multi-core optimizations not affecting core optimizations
Fidelizer Pro
-Added option allowing whether to run core optimizations automatically on startup or not
-Fixed disabled services not enabling on machine configuration where it should be enabled
-Fixed Fidelizer Pro not remembering system configuration option selection
With the big changes in new website, we couldn’t make such small update for such events, can we? In version 6.4, we fixed some bugs and corrected more verification for compatibility with system and Audiophile Optimizer.
Download: Fidelizer 6.4
Upgrade: Fidelizer Upgrade Program
Fidelizer 6.5 Released – Some bug fixes
After releasing version 6.4, some Fidelizer Pro users reported about Windows Management Instrumentation service not running. I did check again and found that I placed program order incorrectly causing service detection failure on case of running Extremist optimization level. This doesn’t happen to free/Plus users.
Changelog for version 6.5
Fidelizer
-Added enabling Windows Management Instrumentation service automatically
-Fixed service verification to run properly
Fidelizer Plus
Fidelizer Pro
-Removed Windows Management Instrumentation service from services list
I also add auto-enable feature on Windows Management Instrumentation service. I hope this won’t violate the rules to not causing permanent changes because it’s enabled by default already.
Download: Fidelizer 6.5
