Fix output to tube amplifier
Artorious88
2
37
Hello,
I am new to the forum, but i have a noob question.
-Can i use the fix output to run into a tube amplifier that has a volume control?
Or would that not be a good idea?
Reason is i have already the var output used up for an amplifier and would like to use the fix output since its free.
Thank you
Should be no problem assuming the fixed output is compatible with the amp's input. Try and see. Make sure the amp is off when you connect, and make sure the volume control on the amp is turned all the way down before turning it back on.
You could also use a simple "Y" cable to split the variable output to the amplifier. You may have problems matching gain if the tube amp's gain is less than whatever other amp you are using (the tube amp would not get loud enough).
HTH - Don
HTH - Don
I see, thank you for the response! I wanted to ask because i can't find info on fix output. I know for sure that it sends out a full range and without a volume control it'll probably blown something in the amp.
If i were to use the splitter for the var output would that reduce the sound quality?
You said the tube amp has a volume control, so you don't need to worry about blowing anything. Just turn the volume control down all the way when you initially connect, as suggested by DonH50.
Connecting to the fixed output is the best way to connect. It is likely that the fixed output bypasses a portion of the driving preamp. A splitter will not sound as good, will not be as convenient, and could result in an impedance concern.
