Hi, I just bought some new Maggies! 1.7i's. I have a few questions about how to put the speaker stands on.
First it says I should use 2 spacers? Is that correct? Does everyone use the spacers? (Also the spacers are the white plastic circles, right?)
Next question, where do these spacers go? It says on the bottom mounting bolt? Does that mean they go on the bolt and then the bolt into the speaker like washers?
Last question, it then says that if I use the spacers, that I should use longer bolts? It appears to come with longer bolts, so does that mean I unscrew the bottom one, add 2 spacers to one of the longer ones included, and then screw the longer ones only into the bottom mounting?
I wish they included some pictures!
Anyway, thanks for your time.
