HIJIRI
jasbirnandra
264
23
923
Dear all I am thinking of changing my IC and speaker cables to the Hijiri million but as cost is a big factor can only do one at a time.
So what are your suggestion which should be the first cable I should purchase to give me the best results.
Currently I have O2A ULTIME cables.
For power cables I have all Oyaide GPX R V2 which are very good.
hello Jasbirnandra,
What is your system?
I have Hijiri Million XLR, and Takumi power cable.
The rest of my cables are Furutech Lineflux, Digiflux, Speakerflux.
Power cord are Hijiri Nagomi, HMS Suprema, Oyaide Vondita.
Pilium integrated leonidas, ideon EOS stream with clock and ideon ION dac with audio solution virtuoso M speakers and million RCA speaker cable and Nagomi PC all
Reactions: hongkongfoufou
I would say fom my experience, that IC between pre-power is where gains are substantial.
That is what i will do myself since i already have good musical power cords on the level of Nagomi.
Since you have integrated, i still fee that dac-integrated connection still would give you results you seek.
From HIJIRI thread from audiogon when asked same question:
"I can't speak specifically to this brand but generally and consistently over the years I've found PC>IC>SC in terms of most impact.
Charles"
Charles"
I have a big difference between my preamplifier and my amplifier with Hijiri Million XLR .
Better bass
Better voices
This cable is better than the Furutech Lineflux in my setup.
