You tell him John.One can judge this by the amount & continuous deflections he uses.
No and maybeit was a suggestion by my son when I asked him what I could do to improve my Ethernet connection. he said that optical is much superior. I've not yet got it done yet. he has to order the pieces. he is our network engineer but I'm not in a position to judge his competence really.
enlighten me.....is this wrong?
In such a short cable, you have to really, really go out of your way to corrupt any data. Rated at 100 meters/330 feet, a 3-6 foot section has way high of a signal to noise ratio to suffer from any ills.
I am going to go back to sipping my Earl Gray tea just the same.![]()
...Lastly the conversion device may have poor power, which could then couple to the analog section, or change it; but it's unlikely you're getting coupling from ethernet.
Consumer grade stuff rarely ever has safety ground for ethernet. And I've already mentioned CMC's for ethernet.
Safety ground has nothing to do with the ethernet, it's only there for electrical shock protection of the device enclosure. Common-mode noise can transfer across ethernet despite differential signaling. Common-mode noise can increase data conversion jitter, as well as cause various analog domain artifacts. Transformers greatly help, but feature a CMRR that degrades significantly as noise frequency increases, hence the app note's recommendation of including high frequency CMCs.
That's a problem for the converter.
You have some data on that relative to the topic of this thread, i.e. differences between Ethernet cables?One of the problems is that in digital signalling the noise budget considerations are focussed on minimising bit errors - not so on the analogue side. It's now becoming evident that certain types of low level noise audibly effect audio output. This is without any bit errors being introduced in digital signal communication.
If by data you mean measurements then no, it's too early - this is still at the investigative stage & like any such investigation evidence of effect & circumstances are being accumulated. This may eventually lead to some solid measurements but it will only come from people who understand the underlying premise for what is going on & as a result, employ careful measurement techniques designed to uncover the mechanism - it won't come from those who employ standard measurements & don't understand the noise that is being discussed here.You have some data on that relative to the topic of this thread, i.e. differences between Ethernet cables?
You know that you often have to go under the surface to uncover facts - for instance, seeing as you are so interested in Ferris Buellers Day Off, you know that it wasn't really a 1961 Ferrari 250 GT California, they used in the film, don't you?
I have no direct experience with ethernet cables making an audible difference but have with USB cables & USB transmission - that's my data point. Not too dissimilar operational factors, differential, packet based protocol but ethernet is pure differential & can make use of a transformer, conferring a certain amount of isolation while USB needs to drop back to single ended transmission for certain messages & therefore can't use transformers.
You could have stopped at No... you know![]()
You think? I don't deal in binary - I find the world much more interesting & nuanced than that
Anyway, I'm Irish & we don't use one word when we can do so in 100 words instead - we're nothing if not story tellers![]()
