Yes. I love the look. With the new feet they now look a bit like penguins.I love the shape of Giyas, somehow they remind me of the top of soft serve ice cream, where they detach from the machine and are birthed into the world as a instrument of tasty delight . . .
No use crying over split milk, but I will cry over melted ice cream .
You are surely wrong in the first part, but right in the second!I mean, who doesn't want more bass in their life? I know I do Lol.
But the story is not so much "more", but of what quality and character, and also when.
That's the perfect solution to my ugly buy amazingly effective Gaia feet on my Giya's
The amount of/ relative volume of bass is what the composer or artist intended, not what you can turn up the bass control to achieve. If you just want lots of bass, that's easy to do with subs etc, but I agree with the second part where you talk about quality and character.
My experience of Gaias under my Avantgarde speakers (and Martin Logan ones) on a solid timber floor (concrete underneath) is the bass VOLUME is slightly less than with spikes (but easily adjusted if required), but that the QUALITY is improved in that the detail and clarity are significantly better.
Spiritofmusic seems to be a lone voive in advocating the rarely found RevOpods, but I'm sure they are good. It's just that he alone seems to write about them. Nothing wrong with that, but there are far more Gaia users than RevOpod ones!
...I think you are correct that REL counsels against isolation, but they never visited my room. I used the EVPs on small T9s to very good effect. Floor is engineered wood over concrete pad, with 3mm felt/poly vapor barrier (basement).whether to put EVPs under the REL 25s though REL does not approve of any isolation on their subs (?).
I believe Jim Smith uses EVP's under his REL's and said they had were a signifiant benefit....I think you are correct that REL counsels against isolation, but they never visited my room. I used the EVPs on small T9s to very good effect. Floor is engineered wood over concrete pad, with 3mm felt/poly vapor barrier (basement).
Without EVPs subs would dance on bass-heavy tracks. Try that Billy Eilish "Zanny" track even if not your cup of tea.
Re: OP... I use Iso-Acoustics Gaias on Magico A5s. I prefer them over the stock spikes. No loss of detail, that's for sure. Soundstage is excellent. I used the "lighter" version on some Revel Studio2s as well, to good effect.
+1 on Townshend Podium PlatformsHaving owned Gias and trialed Revopods ( a friends set) they both elicited pros yet minuses … By some margine the most effective solution under my CLX’s on a parquet floor over suspended floorboards of hell were Townshend Podium platforms , However with the very sad passing of Max I am unsure of recommending the product for obvious reasons . The video shows me manually pressing on the speaker base and does not represent the micro suspension deflection whilst under signal conditions
If you're in the states, you can get them from Music Direct and return them for a full refund within 60 days if they don't work out for you.My speakers weight in @133 pounds each and so far the Gaia l’s are the only feet that will handle them. Are they really worth $1k plus Carpet feet?
Is there a used market or a try before you buy for them?
Thanks.
Excellent addition !If you're in the states, you can get them from Music Direct and return them for a full refund within 60 days if they don't work out for you.
Interesting that they seemed to select those outside the hobby with potentially least trained listening skills for opinion.IsoAcoustics is currently running ads on YouTube promoting their Gaia speaker isolators based on a panel of ordinary people detecting the difference in sound enhanced by their product.
Not I.Who has directly compared the use of their products to the common use of speaker spikes or other methods ?
Don't know.As well, how do IsoAcoustic component isolators compare to premium products like Absolute Sound's Product of the Year ~ Critical Mass Systems ?
When it comes to vibration isolation, I'd venture the answer is nobody knows because when truly following isolation principles, it really ought not matter because it's all isolated anyway, right?Lastly, how does one know when to incorporate 3 or 4 units under a component ?
Thank you in advance for sharing your real world experience and expertise.
Curious where one might find the Arya RevOpods for sale or audition here in the U.S.A.?This is exactly what I was determined to find out. Your input is very much appreciated. I was hoping, I was not just going down the path of previous posts, but seeking enlightenment as to cause and effect. I extend my gratitude for your kind reply . . .
Arya Audio Labs Ltd | RevOpod
Advanced vibration control footers featuring micro precision height adjustmentwww.arya-audio.com
Borderline Gaia I or II.My speakers weight in @133 pounds each and so far the Gaia l’s are the only feet that will handle them. Are they really worth $1k plus Carpet feet?
Thanks.
