Looks like a great buy Keith!, I have always lusted for VAC gear and the Phi series are definitely SOTA, I am sure you will get lots of pleasant listening hours on it.
How is this amp getting 110 watts out of a pair of KT-88 tubes? My ARC VS115 uses four KT-120s per channel and it has roughly the same output. 60-75 watts is more the norm with a pair of KT-88s.
Modern KT88's used in class AB1 can supply more than 100W - see the KT88 Shuguang claims:
The KT88-Shuguang has an absolute maximum anode dissipation rating of 50W and is designed
for use in the output stage of an a.f. amplifier. Two tubes in Class AB1 give a continuous output of up
to 120W.
In order to do that, they would have to run a very high plate voltage. And, tubes should never be run at their maximum design values if you expect long life out of them. The only way that I can see that VAC is getting anything close to the power output they are claiming is that they are running these tubes flat out to their maximum ratings.
VAC amplifiers are known to be very reliable - at less my old PA80/80 could operate for several years with the same power tubes. It was a great amplifier and last time I heard about it it was driving a pair of Sonus Faber Amati homage with success. You would love the PA80/80 - it had four slots in the front panel for easy biasing with two color LEDs for each tube - no need to perform brain surgeries on them!
I don't need more than 20, so it's not terribly important to me - but I've never heard of Vacs burning through lots of tubes like Jadis or some other brands. In fact, doesn't VTL run tubes hard?
I'm not sure Kevin is a proponent of the KT120?
How does Luke Manley get the 450 watts from the same number of tubes as my cj that puts out 275 watts? Yet, my friends VTL MB450 Mk. II has been utterly reliable since the day he bought it.
Not surprised , Luke Manley told me the same thing , surprisingly Bob Carver loves them ....
Great looking piece, enjoy~Here are a few iPhone shots in the house- the unit is quite large, but exudes so much eye candy it's a welcome addition to my room. Sound is very, very good. Bass is tremendous. Will tube roll a bit as I move along, but what a sensational piece. It sounds better than the Vac Phi 200 I had in my system (with a diff preamp of course). Could be synergy, could be BT KT88s, no idea.
View attachment 6640View attachment 6641
