I spy a Big7 HeadDac…can you spot it? LoL
I believe the Balanced Lampi 7 will be up on site tomorro . Supposedly quiter , more dynamic with a larger soundstage . You do however give up the option of rolling tubes , as it can only accomodate the 101D tube in it's current iteration . By general consensus , is the 101D the better tube amogst others for the 7 ? Maybe those with more hands on experience could chime in
Anybody heard the new Lampi 211 100 W push pull amp yet ?
I have the Psvane 101d WE replicas, which are the 101Ds that come with the GG. I like them best, but two guys who were at my place preferred the 6A3s. Thing is, they are very different. 6A3 is smoother, soundstage back but wide, better for vocals. 101Ds more forward soundstage, out in the room, better bass, high frequency, and more details. I prefer it for orchestral. That said, original WE 101D at $2k is probably the best, but a year later you might read a post saying the WE 300b is better. Some people just like the idea of tube rolling and changing sound. But otherwise if you stick to 101d you will still have a quality product, and probably the best tube depending on your preference.
Not to disagree but the 101 d are detail monsters the most analytical of any tube I own. But they do not slam. They are somehow a bit thin with some music . Now maybe wtih classical I can see it being what's needed , but of its a thin recording to over whelming.
Now you take on 6 A3 is spot on and it's why I like them best for some music. I M amid forward guy. Maybe it's my hearing.
For me the eml 45 is a good string point and it's how the dsc should be sold but agin my taste and view. The globes are a great all around tube adding some meat and extra details so my best choice for classical. We must consider the syetem we use to give better choice selection. I am a headphone planar guy and infinity owner so ribbons are just best for me. But a person with a dome may want the 101 d. But given the B7 does so many tubes it's tough to imagine a dac that can be so versatile and system synergistic .
I do feel mike is off with the PCM I think it's very good but it may be the tubes make it a little more lush as SS dsc would be a little more biting as PCM is. For me it's very good both ways. But it's still a great review and loads of honesty in his statements . I am pleased at what he wrote even if it's not all I feel. He might of liked the PCM more worth the 101d though due to there more linear and analitical presentation. What recti did he have this too maters plenty ??
I asked Lukasz about the 211 amp and this was his response:
"THis is our best product to date, outshadowing even the DACs. It is not a typical push-pull, which sounds inferior to SET because of damned PHASE SPLITTER circuit. In our amp we do not split the phase, we do not touch it. On the contrary - our monoblock is effectively TWO SET mono amps in one chassis that share a summator output transformer. So not only the signal is as pure as SET but it also gets error cancellations and humming cancellation due to mirroring of the signals.
All that is possible only with true balanced XLR inputs of balanced audio, but our DACS are all balanced internally. Even the Big7 and Golden Gate are now available as balanced.
211 amp unlike many others has ONLY ONE amplification stage in input section - one SET 803Ecc. And it has extremely powerful White Follower drivers per each phase. All in all the amp represents the simplest purest form of 100 W power possible. "
Sounds very promising indeed!
Those on the site are SE. These new ones are apparently push-pull with a twist and are 100wpc. Triode sound with power??
Hi for me it's the opposite experience. Bill, who heard mine with both 6A3 and 101D, will tell you the same thing. The 6A3 was smoother and nicer on vocals, but it was slower and less slam than the 101ds. On classical the 101Ds slam pretty well, they are not thin, are thicker, actually, great bass. Mind you I was using the one with the bakelite base. I have just bought the ones with the metal base and am burning them in
Ok, and it's 100wpc, or 50wpc?
100W, it's mentioned as an option in the pull down price menu of the 211 amp .
First thing to determine, what rectis are you guys using with the replica WE 110ds. That may make the big difference in performance. Recall that recti voltage drop and wheether they are DH or indirectly heated makes a big impact.
Bonzo, I assume the bakelite base was also PSVANE and NOT vintage WE 101ds?
I know AL has vintage WE bakelite base 101ds and Psvane metals base 101d. He may even have the white ceramic base Psvane 101ds like me.
I have Psvane ceramic 101d globes (treasure/hifi series) and vintage WE 101d (ST shape).
