LL2.1 & LP2.1 tube sources?
rich121
73
28
98
Yakima, Washington
Would like to know best tube sources for my LL2.1 preamp and LP2.1 phono
tima
4,702
5,241
1,195
the Upper Midwest
Would like to know best tube sources for my LL2.1 preamp and LP2.1 phono since Lamm does not have anything resembling customer service.
Lamm works through their dealer network. Have you spoken to your Lamm dealer? There are several here on WBF including Steve Williams, (@Steve Williams) David Karmeli (@ddk) and Gestalt Audio (@gestalt). If you are polite I'm confident a dealer will be able to help you. I"ve found Lamm has excellent customer service if you give them time to get back to you, as noted here: Contact Lamm
LP2.1 Tube Complement:
Other than the rectifier tube, V101 - V104 are Russian tubes. You can find them for sale on ebay. If you want them tested and matched, then Lamm or a Lamm dealer with stock is probably your best source.
V101 -6C3P / 6C3П, left channel, first amplification stage;
V102 – 6C3P / 6C3П, right channel, first amplification stage;
V103 – 6C45P-E / 6C45П-E (original), left channel, second amplification stage;
V104 – 6C45P-E / 6C45П-E (original), right channel, second amplification stage;
V105 – 6X4, full wave voltage rectifier.
LL2.1 Tube Complement:
These are very common tube types. You should be able to find examples from most tube dealers.
V105 – 6X4
you can use: 6X4W, 6X4WA, 6202, EZ90, CV4005, CV493
Left and Right channels each take one of the following:
V101 – 12AU7A
you can use: 12AU7, 12AU7WA, ECC82, E82CC, ECC802, 5814, 5814A, 5963, 6189, 6680, 7730, CV491, CV4003, CV8155
V103 – 6DJ8
Note: changing tubes in a Lamm preamp may require an internal adjustment, eg via a potentiometer, using a voltmeter. Lamm can provide specific instructions if that is needed for either of your models.
Reactions: pcosta and gestalt
rich121
73
28
98
Yakima, Washington
First of all....
When I wanted the Lamm shop to do an inspection/check-up of my LL2.1 last Summer, I did go thru my local Dealer, Jaguar Audio.
Here is his response:
Hello Rick,
You’ll need to contact Lamm.
Regards,
Darin"
It was weeks before I my emails were finally answered by Elina... and only because someone who purchased a lot of gear from them, contacted the company and mentioned that I wanted my preamp checked out.
I also inquired to Jaguar Audio about tubes and again, when I told them I could not reach Lamm:
Hello Rick,
I'm sorry to hear that. I don't have tubes for these. I would take some pictures of them and post them on a tube forum. You'll probably encounter someone who can tell you what they are and where to find them pretty quickly.
Best regards,
Darin"
rich121
73
28
98
Yakima, Washington
V105 – 6X4
V101 – 12AU7A
V103 – 6DJ8
Yes, I already have referenced the FAQ tube information from the Lamm website
Also from the Lamm website:
"We recommend ordering 6C3P and 6C45P-E tubes from Lamm ONLY, as we perform tube selection for each LP2.1 phonostage based on identical tube parameters, and that assures the identical behavior of both its channels. Our in-house designed and built tube testers allow us to measure four different parameters of each tube (in contrast with commercial tube testers that measure only one parameter). Based on gathered data we test and match the tubes with unsurpassed precision that simply has not been available before."
My owners manual has the factory individual readings for each of these tubes, specific to my LP2.1
and states that Lamm matches each as close as possible.
tima
4,702
5,241
1,195
the Upper Midwest
I understand - I've had both models in my system. Although the Lamm Web site lists them, the jaguaraudio.com Web site does not list themselves as a Lamm dealer - it sounds like twice they passed you back to the company. I suggest you check with an active Lamm dealer for a different level of service.
theclipper
9
38
I was thinking of testing out some different rectifier tubes in my LP 2.1. Would I be safe using any of the following tubes: 6X4W, 6X4WA, 6202, EZ90, CV4005, CV493?
Also, any opinions on what the best 6x4 for this phono stage would be?
Thanks!
theclipper
9
38
@rich121 did you have any luck in getting replacement tubes? I reached out to Lamm about a month ago to try and get replacements for my LP2.1. Unfortunately I have yet to hear back.
rich121
73
28
98
Yakima, Washington
For whatever reason it seems to take a month or two for any response.
It might help to send another message.
And yes, after awhile I did finally get them :)
theclipper
9
38
Glad to hear it! I'll have to reach back out to them again this week. Thanks.
theclipper
9
38
Does anyone know of any other source for LP 2.1 tubes? LAMM was going to send me an invoice, but never followed through. They have since been unresponsive to my follow-up emails.
Fishfood
329
354
160
42
I looked around early in the year for these and had zero luck but finally Elina came through with a set for me. You just have to keep trying. One of her dealers that knows her and can contact her directly helped nudge her to return my email.
