Looking for Opinions and Advise
MikeR
14
7
908
For a few years now, I have been putting together the "vintage system" for my old age which has arrived faster then I thought. I
did my research for vintage speakers and intigrated tube amplifiers and then I made my choices, then bought them and
had the required restorations done by qualified techs. i am now at the point were I need to start researching and matching
cartridges for the amplifier and the turntables to get the best sound possible from the equipment.
While it was not that difficult for me to chose amplification and speakers that compliment each other, choosing a cartridge
that does match requires a lot of experience that I do not have, so any advice and knowledge anybody is willing to share is appreciated.
The amplifier is a fully restored to spec. Sansui AU-111, with NOS, Sansui A-603 and A-604 phono input transformers. The amp allows
a TT with a MM cartridge and a TT with a MC cartridge to be plugged into the amp at the same time and by swapping the transformers
and changing between phono 1 and phono 2 with the fuction switch use either the MM cartridge or the MC cartridge
I have choosen two different turn tables for the system and have the first one in use now, it is a JE Michell Focus One with upgraded feet
and a SME 3009 S3 with oil trough and paddles and has the wiring upgrade by Alfred Kayser done for a previous owner.
The second machine will be a JE Michell Reference Orbe, yet to be purchased and a Grado Signature Labratory Standard
tonearm which I have.
Reactions: AudioHR
Which speakers did you choose?
A set of Pioneer HPM 200 speakers, I had read that they are are good with tube gear. All drivers are original the grills are in good shape except for a small hole near one of the badges, and at some point the cabs will get the veneer redone.
Of you want vintage.., I would think a Shure V15 III with a new Jico SAS B will fit the bill.
Not expensive , just good.
I posted my V15 IV with Sas B here. Many Stylus types to Play with giving different results..
Post in thread 'Introducing the Phono Cartridge Measurement Library'
https://audiosciencereview.com/foru...tridge-measurement-library.46108/post-2279189
And V15 III +SAS here,
