I attached the end of the dc connector plug on a male plug (attached/soldered on a resistor). Measured with the probe as indicated in the image.So it was the Uptone cable seen in the photograph that you used. How did you attach a resistor to the end barrel plug? Got a pic of your setup?
Planning to make a load device where the output is connected by bnc to my analyzer where i can select different loads.
correct.Yes, I agree but if you had first measured the device without cable, from it's direct output, you would have answered your initial question - "is it my LPS-1 or my measurement technique that is faulty ?"
