Lumin T3X - A mini X1?
Davehg
24
53
20
PNW
I have the new Lumin T3x running in my second system, and currently burning in. I own an X1 in the main system, and my T2 was feeling long in the tooth. I had wished that Lumin would produce a T3 with a LPS, which they did with the T1 before they migrated to a switching power supply for the T2 and T3. When they used an LPS in the P1 and P1 mini, my hopes increased. This weekend, my dealer sent me home with one to demo for the week, but based on the first few hours this one is likely to stay.
When I moved to the T2 from the D2/Sbooster, there was lots of talk about the benefits and perils of adding an Sbooster. I heard many users state they felt the T2 switching power supply was just fine and minimal benefits to be gained by an LPS. I later added the X1 and relegated the T2 to my second system so I was less focused on upgrading its power supply. There’s always been a hint of digital glaze in comparison to the X1.
So I was pretty excited to read of the T3x and figured this would be a good time to consider an upgrade. In just the first few hours I’m hearing clear improvements. Bass especially is more full, detailed and robust. The hint of digital haze is gone - it sounds much closer to the X1 than the T2. Lots of detail buried in tracks (like being able to isolate background singers and double tracking vocals) that the T3x seems to pull out, and which was less present in the T2. Taller soundstage was a bit of a surprise. It's more transparent but not bright.
I’m going to give it the requisite 50 hours before comparing to the X1 but I’m already thinking it’s a shoe in to replace the T2. I’m speculating that the improved chipset has some role, but really thinking that LPS is a key reason for the improvements I’m hearing. I've ordered up an optical switch and some Finisar SFP modules to try out the optical ethernet connection, which did improve the X1.
More to come, but if the first listen is any indicator, the T3x could be a mini X1 for about 1/3rd the cost.
Reactions: Hyperion
The T3x is indeed exceptional at this level and up. It's much more than "a small update" to the T3.
/ Marcus, www.perfect-sense.se
I skipped the T3 so it’s hard to know what accounts for the pretty large improvements I am hearing over the T2. The ESS DAC is the same and I read where they changed the processor in the T3, so that really just leaves the power supply and the processor, unless they tweaked the analog output stage. But I’m pretty impressed so far. Its making a great case for itself.
I’m up to 35 hours of break in and the sound improved even more. I ordered up an SFP optical Ethernet switch and some Finisar SFP modules as this did improve the X1’s performance. It will be fun to A/B against the X1 when I get time, but I told the dealer I’m keeping the T3x. I’ll post more details when I have everything fully configured.
Reactions: Hyperion
I went from a Lumin D2/SBooster to the T2 without the SBooster. There were definitely sonic improvements with the T2 despite removing the LPS from my earlier configuration. I bought the D2 from a dealer and had them do the necessary internal changes that were required for the SBooster. The T2 was bought used and feel weary about snipping the wires myself. It is something I am still considering but leaning more towards an Entreq Silver Minimus as my next tweak.
