![1d53ba_9986e3f338964dd1926abc2765c3e04d~mv2.jpeg](https://static.wixstatic.com/media/1d53ba_9986e3f338964dd1926abc2765c3e04d~mv2.jpeg/v1/fill/w_961,h_665,al_c,q_85,usm_0.66_1.00_0.01,enc_auto/1d53ba_9986e3f338964dd1926abc2765c3e04d~mv2.jpeg)
Redesigned for the incredible KT170 beam-tetrode power tube, Allnic’s new M-3000 MK3 monoblocks take vacuum tube power and finesse to new heights of excellence. Like the MK2, the MK3 is also a parallel push-pull design, but changing from the KT150 power tube to the KT170 nets more power and even more resolution and transparency. Whereas the MK2 netted 200 watts per amp in pentode mode and more than 90 “SET-like” watts in triode, the MK3 supplies 240 watts in pentode and more than 100 in triode. Of course, like all Allnic’s power amps, that output is also matched by exceptional driving force thanks to Allnic’s KS Park’s optimized circuit design and painstaking gain tube/transformer matching. Like the MK2, the MK3 can also be switched between pentode and triode modes by the press of a button on the front of the chassis - “on-the-fly”.
Much of the improved M-3000 MK3’s refinement is due to the circuit changes Mr. Park made for the MK3 to obtain the best performance from the KT170s. In addition to much larger power and output transformers, which are, of course, Allnic’s hallmark in-house manufactured permalloy specialties, the driver tubes have been changed to the very stable and reliable 5654 in the input position (providing many options for tube-rolling among brands and vintages) to the 6S4 (or 6S4A) triode in the critical second gain position – replacing the triode wired, and increasingly difficult to find, E282F pentode tube wired in triode. Various manufacturers also made the 6S4 over many decades so can also be “rolled”; and as a “pure” triode, it contributes even more to the purity, the crystalline clarity and exemplary resolution of the M-3000 MK3.
![1d53ba_e0a08a73eb5d41a0af30a86e4e6e2a64~mv2.jpeg](https://static.wixstatic.com/media/1d53ba_e0a08a73eb5d41a0af30a86e4e6e2a64~mv2.jpeg/v1/fill/w_958,h_639,al_c,q_85,usm_0.66_1.00_0.01,enc_auto/1d53ba_e0a08a73eb5d41a0af30a86e4e6e2a64~mv2.jpeg)
In addition to the above features, the new M-3000 MK3 monoblocks provide:
? Analogue power tube current monitoring meters
? Exceptionally easy bias controls
? Soft start circuitry
? Individual fuse protection for power tubes
? Dual inputs, one RCA and one XLR
? 4 and 8 ohm speaker terminals (8 and 16 by factory order)
As can be expected, the M-3000 MK3 monoblocks will pair especially well with any of Allnic’s line-stage preamplifiers, from the award winning “little giant” L-6500
hi-fi+ Product of the Year
![1d53ba_3db5a4529e6e4fe88d38388dbab05807~mv2.jpg](https://static.wixstatic.com/media/1d53ba_3db5a4529e6e4fe88d38388dbab05807~mv2.jpg/v1/fill/w_592,h_468,al_c,q_80,usm_0.66_1.00_0.01,enc_auto/1d53ba_3db5a4529e6e4fe88d38388dbab05807~mv2.jpg)
![1d53ba_89384b57953445c48bc039479f2b23a7~mv2.jpg](https://static.wixstatic.com/media/1d53ba_89384b57953445c48bc039479f2b23a7~mv2.jpg/v1/fill/w_295,h_213,al_c,q_80,usm_0.66_1.00_0.01,enc_auto/1d53ba_89384b57953445c48bc039479f2b23a7~mv2.jpg)
To the tour de force, pure direct-heated triode L-8000 DHT.
![1d53ba_63dd5c48b325468aa2d0d33e74b69b1c~mv2.jpg](https://static.wixstatic.com/media/1d53ba_63dd5c48b325468aa2d0d33e74b69b1c~mv2.jpg/v1/fill/w_600,h_381,al_c,q_80,usm_0.66_1.00_0.01,enc_auto/1d53ba_63dd5c48b325468aa2d0d33e74b69b1c~mv2.jpg)
![1d53ba_5402343a826842bbaaf0a2cfac04c163~mv2.jpeg](https://static.wixstatic.com/media/1d53ba_5402343a826842bbaaf0a2cfac04c163~mv2.jpeg/v1/fill/w_132,h_265,al_c,q_80,usm_0.66_1.00_0.01,enc_auto/1d53ba_5402343a826842bbaaf0a2cfac04c163~mv2.jpeg)
![1d53ba_6eae4027833c49debb32bcad94ae5a23~mv2.png](https://static.wixstatic.com/media/1d53ba_6eae4027833c49debb32bcad94ae5a23~mv2.png/v1/fill/w_225,h_225,al_c,q_85,usm_0.66_1.00_0.01,enc_auto/1d53ba_6eae4027833c49debb32bcad94ae5a23~mv2.png)
Audiophilia Product of the Year
The M-3000 MK3 monoblocks are a vacuum tube-based marvel of audio engineering. Their power, stability, and clarity are matched by their weight; at 36kg, almost 80lbs, per chassis, caution is advised when you are moving them around. Fortunately, the design also features handles – in the right places - to provide a great deal of ergonomic efficiency for moving them around safely.![1d53ba_f0991b556882435a9aca053ea261abf7~mv2.jpeg](https://static.wixstatic.com/media/1d53ba_f0991b556882435a9aca053ea261abf7~mv2.jpeg/v1/fill/w_959,h_601,al_c,q_85,usm_0.66_1.00_0.01,enc_auto/1d53ba_f0991b556882435a9aca053ea261abf7~mv2.jpeg)
The M-3000 MK3s will drive essentially any speaker on the market with outstanding results. If you need significant power and still want all the qualities, the beauty of life-like presentation of a world-class tube power amplifier, the M-3000 MK3s might be for you.
SPECIFICATIONS FOR THE ALLNIC AUDIO M-3000 MK 3 KT170 MONOBLOCK POWER AMPLIFIER
• Output Power: • 240w (8? load, at 1KHz) Pentode
• >100w (8? load, at 1KHz) Triode
• Distortion: • 0.17% at 1KHz at 10w
• Frequency Response: • 20Hz - 20KHz Flat
• S/N Ratio: • -80dB (CCIR, 1KHz)
• Damping Factor: • 8 at 8? load at 1KHz
• Voltage gain: • +28dB
• Input Impedance: • 100K? (single-ended, unbalanced)
• Input Sensitivity: • 2.0V for maximum rated power
• Fuses: Mains:
AC 10A, 250V – 6x20mm slow-blow for 110/120V regions
AC 5A, 250V – 6x20mm slow-blow for 230/240V regions
KT170s: 0.5A, 250V - 6x20mm slow-blow
• Tubes (per chassis): • KT170 X 4 (power tube)
• 6S4 X 2 (second stage drivers – equivalent to 6S4A)
• 5654 X 1 (first stage driver – equivalent to 5654W, 6AK5, 6AK5W, EF95 and CV1762)
• Dimensions: • (W x D x H) 430mm (16.93 inches) x 430mm (16.93 inches) X 290mm (11.4 inches)
• Weight: • 36 kg/79.4 lbs net per monoblock.
• 43 kg/ 94.8 lbs shipping weight per monoblock
M-3000 MK3 Monoblocks:
2024 MSRP: $30,000/pair, Contact your regional dealer for introductory pricing.
Contact your regional representative for more information: Allnic Distribution
AND BEFORE YOU GO – OR GO ON TO READ THE ALLNIC PRODUCT OVERVIEW BELOW, PLEASE TAKE A LOOK AT THIS BRAND-NEW VIDEO by Canada's renowned reviewer, Youtube page, Jay's iyagi FEATURING AN INTERVIEW WITH ALLNIC’S KS PARK!
https://www.youtube.com/watch?v=0MzkZ8H4z98
Allnic Product Manual Page
The product manual is attached below:
