I've always wondered how well those work. It might be useful for me -- I have a window behind my speakers and I hate blocking it with diffusers.
+1....those are beautiful! Who did this work?My suggestion to Magnepan build sth like this:
That I've done -- the problem is that when I put a diffuser there, it blocks the window (midrange/tweeter panels are on the inside):All you have to do is intercept the parts of the first reflections which are headed towards the sweet spot.
Sit in the sweet spot and have an assistant place a mirror up against the wall, and move it around until you see either the front or the back of Maggie in the mirror. That's where the reflection happens. Place the fake Ficus (or its functional equivalent) someplace where it will block your view of Maggie - and it doesn't have to be exactly at the reflection spot if that happens to be impractical.
If you don't have a mirror and an assistant, use your imagination and you can probably judge where the reflection spots are pretty well.
The idea is, to prevent strong distinct ("specular") early reflections, as those are the ones most likely to have negative effects.
In general I prefer diffusion to absorption because diffusion doesn't mess with the spectral balance of the reverberant energy. Absorption is more effective at short wavelengths than at longer ones and correspondingly tends to alter the spectral balance of the reflections quite a bit, which imo is generally not a good idea.
Thanks Troy -- it was looking better then than it is now, it's all ripped apart because I had to have the ceiling repaired! I think I'll move the amps to the right when I put everything back together, and try the new Vicoustic diffusers. But that's not going to happen for a while, since there are more renovations to be done.Your system is really looking good Josh, including the projection screen tv.
I took a couple of days off, so I can take my time on the drive back. I'll be attending the December 11th event, at Quintessence Audio. Really looking forward to hearing the Condo Mag's, seeing their size factor is small maybe I can get Wendell to swap them into the "tweets in" position, haha:;>
Quintessence Audio is in Morton Grove IL, which Google maps says is 15.9 miles and 33 minutes from Chicago. It also says I was there 4 yrs ago, forgot it was that long ago. I went to hear some of the Magico line of speakers, I think that I ended up preferring the Sonus Faber speakers.
Some more reviews:
https://www.hifiplus.com/articles/coming-soon-maybe-magnepans-compact-307-for-condos/
https://www.dagogo.com/magnepan-lrs-speakers-review/
