Masking small scratches on Spectral Frontplates
Console
32
5
138
Timbuktu ;)
Hi there,
Is there any color or way to mask very light scratches on Soectral Frontplates? I have some on the DMA 180, which you can see if you put direct light on it. Not really bad, but I love my babies and it would be great to have them mint looking... :)
Thanks for any tips!
Console
I found a wonderful trick! All super light scratches are GONE, the slightly thicker ones significantly less visible! :)
Polish it with Tooth paste (no whitener!) with a dry cloth. Rub firmly with feeling for 1 minute... Clean with slightly wet cloth. Dry with another cloth... Done you are: Scratches gone!
:) Probably helpful for you, guys!
Best Console
Best Console
Wow, thank you. I just tried that and it works!
