I state that -6dB point, giving a lot of amps the benefit of the doubt. My experience mirrors yours in this regard- many SETs have less usable power than 20%!
Much of what you state here is false. IMD is a
very audible distortion subjectively (and has a lot in common with the way the ear perceives aliasing) and this fact is well-known and should not be a topic of debate! The ear uses higher ordered harmonics to sense how loud sounds actually are, and the ear is a range in excess of 120dB. So it is keenly sensitive to the higher orders as well. This is very easy to demonstrate with simple test equipment! If you look at musical instrument waveforms (with any accuracy), you'll see the higher orders play a role in how those instruments sound. The idea that distortion isn't audible is really ridiculous: harmonics
define the sound of any instrument and by distorting the harmonic makeup of them, you change their sound. So often harmonic distortion is treated as something that is so many 'dB down' from the actual signal- I find this really amusing since the signal itself is being modified by that distortion.
The difference between a solid state amp with higher ordered harmonics and an SET is the solid state amp maintains low distortion as power is increased. SETs do not- the distortion rises fairly linearly (and relatively speaking, dramatically) as the power is increased. Feedback is preventing this behavior in solid state amps. Their brightness and harshness comes from two things. The feedback signal being distorted before it can even do its job due to it being applied to a non-linear point in the amplifier (usually the input of a semiconductor) and the circuit usually lacks the Gain Bandwidth Product to support the feedback over the entire audio range- so distortion is higher at high frequencies- usually right in the range of the ear's most sensitive area (Fletcher Munson).
So this behavior of SETs is very real
and easy to measure. Its also easy to
hear- and once you know that 'dynamic' quality is coming from distortion rather than the signal (which is where it
should come from) it kinda wreaks it. Again: the ear perceives more higher ordered harmonic distortion as increased sound pressure which easy to demonstrate with simple test equipment (procedure available on request).
This is utter BS. Nonsense. Either a measurement error or he didn't realize that distortion makes tube amps seem to have more power than solid state due to how our ears interact with distortion (as I've written about ad nauseum). SETs, lacking feedback, can behave differently with regards to voltage vs load since they behave more like power sources than they do voltage sources. So when working with them you will see the voltage rise with the impedance of the load- but the truth of the matter is revealed when you calculate the actual output power. So it can appear to behave differently than solid state, which tends to act as a voltage source. More on this phenomena at
http://www.atma-sphere.com/en/resources-paradigms-in-amplifier-design.html
Ears are different and people have different taste, but the
rules our ears use are
the same across the entire world population. For example, our ears use a logarithmic scale for sound pressure rather than linear- which is why we use deciBels to denote sound pressure. How we detect sound pressure is the same. Our sensitivity to higher frequencies is the same (hence musical instruments are built the way they are). If our ears used different perceptual rules it would be impossible to design audio equipment plain and simple.
One must be careful to not conflate the rules of human hearing perception with taste!
