Which, without further work on both sides, does not invalidate (or validate) either position...
Correct.
Tim
Correct.
Tim
If A then B then C. If Don agrees with Greg and Tim agrees Don, then that means Tim agrees with Greg. lol.
Careful microstrip.Do you think audiophiles should be sentenced to listen just to to good midfi until some one develops such measurement techniques? Or should they join the high-end manufacturers in exile?
Maybe this is like most on-line debates a matter of semantics, maybe it is more than that. But IMO the objective of an audio system is to reproduce audio (which may or may not be music), which is not per se subjective. Perception may be subjective, but reproducing audio most certainly is not. The audio system does not know one way or the other if a living creature even is listening, let alone whether the sound is of a character some will enjoy, find fatiguing, or used for the purpose of, as the 2006 Isley Brothers' recent album was entitled, "Baby Making Music".You seem to forget the objective of an audio system is to reproduce music, that is per se is subjective. Why should manufacturers of the better devices focus on a set of parameters that do not correlate with their excellence, and just seem to define the generally acceptable threshold?
Careful microstrip.
Then there is that pesky little term again, "better". Who gets to decide? What are the grounds for such a decision? What if someone disagrees?
It is one thing to argue that there are insufficient measurements which can be used to predict whether one will care for the sound of a particular component but quite another to assert that all will care for that sound as well as agree that that sound is *better*. Even Harman's speaker tests don't go that far.
The strawman argument apparently knows no bounds.
Accurate, high resolution in-room measurements, along with acoustical corrections and equalization are necessary to deliver truly good sound to listeners' ears in homes and in studios." [Emphasis original.]
Like this quote from Floyd Toole?
This is a statement that you have repeated often, Tim, and I, and I think others have trouble with it. The history of science is littered with such bold assertions by those at the top of their fields, who have the highest level of recognition by others, as a reaction to some new bold concept proposed by some generally unrecognised, irritating whippersnapper. In fact, a chap called Einstein was virtually completely ignored for about a decade, after his most famous papers were published.Often what they hear is impossible, so I do not need any testing or direct experience to know they are imagining it. Most of the time, I expect it is just a penchant for drama an hyperbole. This much I know from reading and experience -- on many occasions the obvious differences reported in isolation became difficult, if possible, to discern in direct comparison, blind or otherwise.
Looks interesting, Roger, except I note this point: "It is assumed that both versions are simultaneously available in computer files and that they are synchronized in time". This was the problem for Gary's experiments with TT sound, getting perfect synchronisation."CRC has developed a novel and proprietary software called "Perceval" to objectively assess and measure the quality of a processed audio sequence relative to an original unprocessed version of the same sequence."
http://www.crc.gc.ca/en/html/crc/home/tech_transfer/10079
Toole's words keep getting referenced around here in the context of anti-mesurement arguments. Tim
Toole's words keep getting referenced around here in the context of anti-mesurement arguments. I don't doubt that he believes in listening, or that he believes that many things audio come down to choices. But I do not believe he is a subjectivist in the sense that the members here who are bringing him up believe he is. Could someone making this questionable connection please quote him, in context?
Tim
Not having a go at anyone, but that's a bit of a weasel phrase. You can stretch the word "reasonably" great distances in many directions ...Let's go a little further with the argument that the component " measures adequately to to produce a reasonably perfect replica of it's input.
