Nagra Jazz Amp
duvidl
2
Good morning all
I am seeking advice regarding a potential purchase i am looking to make.
I have the opportunity to acquire an Nagra Jazz Pre-amp and i wanted to know if it would be worth adding to the system i currently use which includes:
Rogers LS/8 Speakers
Revox Tuner
Quad 606 power amp
Linn Turntable
I appreciate the Nagra is a few levels above the standard of what i am currently using but assistance in letting me know wether i am wasting my time would be appreciated.
Also, with the Nagra using XLR cables, is there egging to be a reduction in performance having to use XLR to RCA or to Din in order to connect up my units?
Good morning all
Revox Tuner
Quad 606 power amp
Linn Turntable
The Nagra Jazz is a really really awesome preamp. I've always thought a great pre amp is the heart of a system. I don't think you'll be wasting your time or money. It's a piece that will last a lifetime...just 3 tubes to replace every 4-5 years. The Jazz does have XLR or RCA ins/outs so not sure what adaptors you'll need. Even so...if you happen to need a adaptor, if you get a wall made one from Cardas, Purist or Transparent for example, it likely won't be noticed sound wise...Best of luck.
Thanks very much for your reply. I think I will make the purchase
I used to have four Nagra components which were transport, DAC and amplifiers. Now I have one. I moved in another direction, if you have a dem listen with your heart as well as your ears.
