i will not try to answer beyond your specific question. but know there are many decks when in really great condition can perform at a high level, my preferences are not intended to be comprehensive.@Mike Lavigne
Which deck is your favorite and which is your best sounding?
A well maintained machine should not have significant noise. However, loss of lubricants on old tapes can cause squeaking. This can be ameliorated by applying Last tape preservative or silicone fluid.What is the minimum distance one should sit from a tape machine in order to not hear the machine itself during playback? I understand that all machines/tapes make some noise during playback, unlike a record player, for example.
My Nagra T Audio developed noises, and it turned out to be due to deteriorating belts. After replacing these, the machine no longer makes any noise. Even my refurbished Revox B77 is pretty quiet.Some machines are quite noisy among others the Telefunken M15 and the Sony APR 5003V. I have 3 fully overhauled capstan motors for my Studer A80 and I selected the quietest. But indeed a good and well maintained machine should not have significant noise.
There are always going to be some sample-to-sample variations... so my M15A is very quiet, but the Sony I can hear 10-12' away... however, the ATR-102's are always quiet...I am sure in part due to the fact their 2.5" diameter capstan is barely spinning.Some machines are quite noisy among others the Telefunken M15 and the Sony APR 5003V. I have 3 fully overhauled capstan motors for my Studer A80 and I selected the quietest. But indeed a good and well maintained machine should not have significant noise.
Interesting, thanks. But then a faster spinnIng capstan has more precise speed control… I guess it’s all trade-offs, like with everything else.There are always going to be some sample-to-sample variations... so my M15A is very quiet, but the Sony I can hear 10-12' away... however, the ATR-102's are always quiet...I am sure in part due to the fact their 2.5" diameter capstan is barely spinning.At 15ips there is nothing there spinning faster than 2rpm. The reels, of course, are not doing more than 1rpm.
And what is that reason?If that was true then everyone would be using 2mm or 1mm capstans... in reality large diameter capstans are normally used in high quality machines. There is very good reason for that.
