Origin record clamp
Steven Meltzer
1
71
Can anyone tell me if the Origin record clamp should sit on top of the turntable spindle and NOT make contact with the record surface?
Thanks
Lagonda
3,515
4,825
1,255
Denmark
Thanks
Ha Ha Ha ! :p What would be the purpose ? Your spindle is either to thick or to long, normally a good problem to have !;) Last time i bought a record clamp with this problem i drilled it out a little ! Measure first ! You could return it and have them do it, Mark Baker always aims to please !
audio.bill
549
82
340
Chicago suburbs
The Origin Live Gravity One is designed to be in contact with the record label area to effectively damp vibrations in the vinyl. It isn't a clamp nor is it very heavy like many other such devices and is not designed to flatten warped records. It claims to "make a significant contribution to improving bass definition, weight and depth but it also enhances the mid-band and treble through better separation, transparency and decay of notes." The reviews seem to support the claims, being confirmed both by professional reviewers and customer feedback.
