Phasemation with EAR MC4 Sucks?
I have just received an EAR MC4 and compared to my Cinemag 1254 based SUT its not sounding very good.
The Unit is used. I've tried the 3ohm 6ohm and 12ohm. 3 and 6 ohm sound compressed and lifeless.
The 12 ohm input sounds more alive but not has good as the Cinemag.
The ratio's are 1:30, 1:24, 1:18 and 1:10. I'm using a phasemation pp-200 cart with 4ohm internal impedance.
The Cinemag sounds awesome at the 1:20 setting which matches Phasemations own SUT's that use 1:20.
Phono stage is Ifono3 black label set to 36db gain.
1:20 gives a loading of 118ohm. 1:30 and 1:24 give loadings below 100ohm. I beleive my cart is recommened to see a load of 100ohm
or greater so that explains why 1:30 and 1:24 don't sound right......
However i have read reviews where people have used Phasemation on the 1:30 and 1:24 with EAR MC4 and describe great sound ?!?!...
Does anyone have experience with the EAR SUT's with Phasemation carts? Could this be burn-in related?
If the previous owner never used say the 1:30 3ohm or 1:24 6ohm setting could it just need some running in time? or
am i just looking at a synergy problem where the SUT doesn't really go with this Cart?
Any advice greatefully received.
The phasemation T2000 was quite better than the Head SUT in drect compare with phasemation cart at Rennsalaer.
Edit - Parvacini's The Head, not MC4
I also own a Cinemag 1254 SUT and an Ear MC4, as well as a Phasemation PP-2000 cartridge, among others. The Ear MC4 is definitely in a different league comparing to Cinemag. Initially I thought the Ear was superior to my other SUT (cooper) designed by Dave Slagle - aka Intact Audio or EMIA. However, my perception has changed and today I find Emia more elegant, especially in the higher frequencies - although it doesn't have as full a sound compared to the Ear.
I also own a Cinemag 1254 SUT and an Ear MC4, as well as a Phasemation PP-2000 cartridge, among others. The Ear MC4 is definitely in a different league. Initially I thought the Ear was superior to my other SUT (cooper) designed by Dave Slagle - aka Intact Audio or EMIA. However, my perception has changed and today I find Emia more elegant, especially in the higher frequencies - although it doesn't have as full a sound compared to the Ear.
What input on the MC4 do you use? 12 ohm ?
