Now Mark can you comment on SET or low wattage amplifiers,especially if you have experimented with high efficiency speakers.
Also how does your system image?
Since this system is multi-amped (multiple band spectrums/separate amps for different frequency ranges), it would be challenging to use it with SET power amps in a quick swap out. There are no passive crossover networks, which means I would need numerous individual SET amps to swap out for the numerous SS amps that I have in there now.
I will say that 6 watts is plenty. In fact, the 'signal present' LEDs light up when the power level is at 6 watts on each of the QSC amps and at that point, the SPL measured in the listening position is 129dB. SETs would have no trouble achieving comfortably loud listening levels.
Due to the subwoofer tunings being down in the infrasonic region, I would not expect any ugliness to appear in the sound quality. Though I don't know about the mids. They do benefit from tremendous damping and high current cables. I could do the Bob Carver transfer function experiment and add a resistor in series with the mid/hf drivers and see if driving them as a current source makes for any unusual sound. I'd reckon my pristine square wave response would likely suffer a bit.
System imaging.. now that's a very interesting aspect on its own. Since designing the mid/hf arrays in 1982, I've always had good imaging, and particularly good Sonic Hologram presentation (from Carver's invention which is part of my C4000 preamp). A dealer for Carver in my area listened to the system and informed me it has the best and widest sound stage of anything he's heard in the showroom.
Since my theater conversion, I put some effort into acoustic treatment in this space. I've always had comb filtering issues up to that point, due to a lot of reflective surfaces. Since the addition of lots of absorbtion at crucial locations near, around, above and to the sides of the speakers, the system has taken on a whole new sense of transparency. When I listened to a sweep tone, that was my first indication of radical change. Normally, we'd hear loud and soft, period undulation of the sweep as reflected sound fought with direct sound. After the theater conversion, the sweep was uniform. There was no easily discernable change in amplitude as the sweep progressed.
Then with music, I found that my stereo image with the Sonic Hologram OFF was as good as it used to be when it was ON. And with it ON now, there can be a 360° immersion possible, depending on the content (I recently showed the new
Smurfs movie down here for my daughter and near the end of the film, there was a disembodied voice of one of the characters, which appeared about 12" above my head. With concerts, I get the same sense of being able to point out different sections of the orchestra that I have when I'm sitting in on orchestra rehearsals at the GBS. It's interesting to sit at the fourth row center on Friday night rehearsal, record the concert on Saturday night, and on Sunday night sit and listen to it in my theater. I actually prefer the recorded experience, as it is more detailed, due to the elevation of the mic cluster being able to 'see' an unobstructed view of the orchestra.
The imaging is one of the things that always gets visitors' attention here. That and the unexpected low frequency tactile aspects. I have a lady friend who owns mostly Denon equipment and a pair of B&W 801s. She likes to come over here and play her CDs whenever she buys something new because in her words, "I want to hear what the music really sounds like."
One of the things that people notice is the absolutely solid sense of a phantom center channel on stereo recordings. There's no hole in the middle. Vocals emerge from the space in the center and are very palpable. I used to get a kick out of playing my violin in front of an ORTF pair of condenser mics set up at the front of the room, walking back and forth in front of the mics as I played, then playing the recording back and sitting in the front row center seat. Closing my eyes, I get the sense that someone is actually playing a violin and walking back and forth. The image is not too big--it's about what you'd expect for a violin at 7' distance to the chair.
I get varied and different kinds of soundstages depending on the recording. Most commercial stuff can play manipulation games with the source, and have extraordinary wide soundstages that are unbelievable. Audiophile recordings tend to be natural, that is, nothing extraordinary--just about what you'd expect in a concert hall, which is, IHMO, not very wide, but you can still discern various instruments over a narrower arc.
Last summer, I took Ethan's challenge to identify which of three ADCs was used to make each of three WAV files he posted on his site. Frankly, I though the headphones would be the best for making this distinction. But I could not tell them apart. Then I played them on the speakers and that's when I could clearly identify the differences between the Lavry, the Delta and the SoundBlaster recordings of the same performance. When I want to listen without disturbing, I put on the headphones, but when I really want to hear what the music sounds like, I listen on the main speakers.
