Item-1
Room dimensions are measured from the surface of a wall, floor and ceiling.
However under certain conditions and certain frequencies the room dimensions may seem to be different or react different - as in different lengths.
For Instance in my walk-out basement listening room I have on my left side a densely packed 3.5 foot wide CD rack that projects 7 inches out from the wall and just catches the "first reflection" on the edge closest to my listening position.
Is the acoustic center of the room now shifted to the right 7 inches or maybe 3.5 inches?
I'm going to do an experiment tonight and move my right speaker over to the right, already have the masking tape on the floor to mark the positions.
Item -2
Masonry walls below grade are the core foundation of my room for low bass notes. However, higher frequencies reflect off the furred-out drywall.
Therefore my room is several different sizes depending on the frequency, right?
Item-3
I'm using a 6'x6' Ikea Kallax as a record rack and rear area/zone room divider, another six feet of space lays beyond.
Low ceiling, only 9" higher that the record rack. Narrow room, 30" wide access from rear room entrance each side of record rack in the FUTURE.
Record rack has each cube filled to about 80% of opening.
Is the room divider that is 70% ish solid - counting flanking side openings my acoustic rear wall, or the true wall six feet beyond?
I will be adding sketches to explain clearer, see below.
Item -2
Item-3
